Spektrum
Old 02-19-2006 | 07:13 PM
  #1306
dr_hfuhuhurr's Avatar
So is there anything I can do to help that out? Maybe the power cap on the rx? Anything? I'm really enjoying the brushless.
Blake
dr_hfuhuhurr is offline
Old 02-19-2006 | 07:15 PM
  #1307
Cool, Thanks. Anybody seen the new one for the 3pk yet? Supposed to be faster than the hrs. Dont know if i will go with that or just wait for Futaba's own set up. No wire at all sound kind of cool and suspect at the same time.
tcmerf is offline
Old 02-19-2006 | 07:20 PM
  #1308
RCGaryK's Avatar
Blake, try the SPM1600 cap, see if that works. PM me if you try that and it doesn't fix the problem.
Merf, the new 3pk module is HRS compatible. From talking to several people the Futaba version will not be a US release, just overseas.
RCGaryK is offline
Old 02-19-2006 | 07:27 PM
  #1309
I also read that the wire could be cut to 4.6 inches. Is that from the outside of the caes or do i need to open it up?
tcmerf is offline
Old 02-19-2006 | 07:29 PM
  #1310
RCGaryK's Avatar
You can cut the antenna lead, but there's no real need to. I want to say to like 3.6 inches, but double check the manual first.
RCGaryK is offline
Old 02-19-2006 | 07:30 PM
  #1311
Thanks Gary, I had the shop order me one...it should be waiting on me now. I will also be borrowing a friends 3pk to try out with it to see if I can tell if it's the transmitter or reciever having the problem.
Blake
Old 02-19-2006 | 07:32 PM
  #1312
RCGaryK's Avatar
What radio are you using now? I've personally used 2 different radios, a Helios and a Z-1 and haven't had any issues with either.
RCGaryK is offline
Old 02-19-2006 | 07:34 PM
  #1313
the problem of mine only happens at large track. Not sure what really causes it because other Spektrum users with TC equipped with brushed motors also have problem.
To solve the receiver shutting down is much easier I guess, I solved mine by avoiding old batteries and running 5 cell instead of 4 cell for my 1/12 pan car.
azmio is offline
Old 02-19-2006 | 07:36 PM
  #1314
KO EX1 Mars R
Old 02-19-2006 | 07:58 PM
  #1315
RCGaryK's Avatar
Hmm, odd. I know when I ran with a Tekin Brushless in my Mini-LST I needed to use the cap because the BEC output out the Tekin was too low. The Cap took perfect care of it and it runs awesome now. I know a lot of 1/12th scale guys ran Spektrum in Cleveland, Vegas, and Snowbirds without an issue.
RCGaryK is offline
Old 02-19-2006 | 08:18 PM
  #1316
Is there any info on the web about this? Release date or anything?
Seano is offline
Old 02-19-2006 | 09:06 PM
  #1317
RCGaryK's Avatar
http://www.horizonhobby.com/Products...ProdID=SPM1015
RCGaryK is offline
Old 02-19-2006 | 09:17 PM
  #1318
Thanks, I mean the Futaba PK-FSM 2.4Ghz module and receiver. Have found a little info but not a lot. Anyone have any other info?
Seano is offline
Old 02-19-2006 | 09:21 PM
  #1319
RCGaryK's Avatar
I got nothin, lol
RCGaryK is offline
Old 02-19-2006 | 09:23 PM
  #1320
There is a little information here http://www.rc-car-net.at/rcn/thread....=Futaba+2+4GHz
Seano is offline
