Schumacher cougar LD3 >
Like Tree317Likes
Old 03-31-2026 | 03:57 PM
  #661
Dlewis4's Avatar
Yall making me worried. 3 weeks no replies? Is a new car coming? I just heavily I vested in Schumacher LD3 and CAT PB! Lol
Dlewis4 is offline
Old 03-31-2026 | 06:29 PM
  #662
im hearing from team drivers,a new car this fall
speed101 is offline
Old 03-31-2026 | 06:48 PM
  #663
ChadoSan's Avatar
Don’t expect anything you won’t be able to buy and add on to an LD3. If history holds it won’t be out until LATE in the year.
Only thing I expect at this point is the new bottom plate with an updated steering rack and servo mount, new C and D blocks that have the pill system like the PB, the 5 gear trans maybe in plastic, and maybe the PB slim hubs but that’s a wild card honestly. Every single one of these seems to be mismatched to a specific type of car only using them as well (dirt vs carpet).
I am also wondering if they are moving away from the shorter dog bone setup as I don’t even see them having the listing for the shorter version of the UJ anymore.
ChadoSan is offline
Old 03-31-2026 | 06:49 PM
  #664
ChadoSan's Avatar
MarcosGravy likes this.
ChadoSan is offline
Old 03-31-2026 | 11:49 PM
  #665
Pistol123's Avatar
That was my thinking as well, although we haven't seen the team drivers using the flat servo plate on carpet or astro in the UK that I am aware of. I have invested in the pb hubs and UJ's as it makes it so much easier to adjust the hub height.
Pistol123 is offline
Old 04-02-2026 | 06:32 PM
  #666
ChadoSan's Avatar
PB hubs and UJs should be used as a tuning option. The length of the dog bone makes a difference in handling. It stabilizes the rear more than a shorter length dog bone.
ChadoSan is offline
Old 04-02-2026 | 11:03 PM
  #667
Pistol123's Avatar
Yes, I was already running the longer CVD driveshaft as I had the Dirt hub inserts and wanted to try the UJ's as running medium/high grip astro. So just switched to the PB hubs and UJ's with a 2mm wider hex - was on 4mm and went to 6mm.
Old 04-07-2026 | 11:27 PM
  #668
Pistol123's Avatar
Default 5 Gear Gearbox
Chatting to one of the UK team drivers it looks like the 5 gear gearboxes will be staying in the cars for the outdoor astro season. They are getting better rotation which is enabling them to dial in more rear forward traction.
Currently out of stock in the UK but have one on order to try out.
Old 04-10-2026 | 04:22 PM
  #669
New bits look good:
U9451 - Worlds Flat Servo Conversion - LD2,LD3,ST2 - £69.99
http://www.racing-cars.com/U9451
U9455 - Worlds Rear Suspension Strap Conv. - LD2,LD3,ST2 - £39.99
http://www.racing-cars.com/U9455
Would be nice to see a new LD3 kit released with these bits and the 5 gear included and maybe some of the PB parts as well (rear hubs)
Taz_S and Pistol123 like this.
BuggyFan21 is offline
Old 04-11-2026 | 01:27 AM
  #670
Pistol123's Avatar
Originally Posted by BuggyFan21
New bits look good:
It does look like all the bits that would go into an LD4 are now available off the shelf.
Old 04-11-2026 | 01:29 PM
  #671
madweazl's Avatar
I'm jumping back into 1/10 buggy after a number of years off and will likely go 17.5 initially. We travel fulltime in our RV so I'll end up racing all over the place but I'm just wondering if the S chassis really is the way to go or should I just go with the M?
madweazl is offline
Old 04-16-2026 | 07:09 PM
  #672
ChadoSan's Avatar
Pistol123 likes this.
ChadoSan is offline
Old 04-17-2026 | 04:31 AM
  #673
pink_sleeve's Avatar
You must have one heck of a connect. i haven't even saw these on the Schumacher site available yet.
pink_sleeve is offline
Old 04-17-2026 | 07:01 AM
  #674
Pistol123's Avatar
In the UK (where Schumacher are based) the rear hangers and servo mount are available. I am waiting two weeks for the 5 gear gearbox to be available.
Old 04-19-2026 | 12:17 AM
  #675
Any ideas what alloy servo horns work with the new front end? All I have are too long and hit the top plate and I’m not sure about using the plastic one from the kit.
wiktor0410 is offline
