Like Tree780Likes
MTC3
Old 07-18-2025 | 07:07 AM
  #466
Mach10_shooter's Avatar
Originally Posted by EAMotorsports
Looks awesome! Looks like great quality and finish! But the screw holes look huge on it. Im sure its an optical illusion with the picture tho!
EA
Nope, holes are big...
This thin of material along with using kit screws requires the bulkheads, motor mount, etc. to be touched with a 90 deg countersink and a small amount of material to be removed.
It doesn't really hurt anything but not ideal to be honest. I might do another using the thinner head ARC screws.
Kaspurr84 likes this.
Mach10_shooter is offline
Old 07-18-2025 | 10:43 AM
  #467
Team EAM
The screws AMX use are just called a "Low profile" 3mm CS Screw. You can find them around but they arent typically as good of quality as the amx ones.
EA
EAMotorsports is offline
Old 07-18-2025 | 05:02 PM
  #468
Default Chassis file
curious how are you getting the cnc data for this, flat bed scanner, calipers and cad or 3d scanner?
id love to learn how to reverse engineer like this.
Would you be willing to share the file
Flipside6900 likes this.
thelung is offline
Old 07-18-2025 | 05:13 PM
  #469
blwaz23's Avatar
One way is to buy a chassis and take a good photo. Upload to a CAD software and draw out the shape by overlapping the lines on the photo. Then make sure everything is to scale and double check measurements with a caliper.
blwaz23 is offline
Old 07-18-2025 | 05:55 PM
  #470
Kaspurr84's Avatar
I used to use my old high quality Lexmark flatbed scanner when making smaller parts, especially in my RC heli days, with a lot of flat carbon pieces. Never did a full 1/10 frame. But I'd imagine it would fit in scanner.
Kaspurr84 is offline
Old 07-18-2025 | 06:23 PM
  #471
I use my fingers to measure then check it on a ruler then use the dimensions from the ruler.
LowDrag is offline
Old 07-20-2025 | 12:48 AM
  #472
disaster999's Avatar
Regional Moderator
The manual gave the drawing away...if you know... you know.
lbsnoopy and gigaplex like this.
disaster999 is offline
Old 07-20-2025 | 03:51 AM
  #473
Originally Posted by disaster999
I made my own too with 2.2mm carbon, motor mount and bulkheads all retain the same 1.5mm thickness from stock. just gotta add shims on under the arm to achieve the same roll centers from stock.
Asking the important question: are you planning on selling these or it's just a personal project?
lbsnoopy likes this.
Fastfreddy74 is offline
Old 07-20-2025 | 06:28 AM
  #474
Regional Moderator
I havent even tried this myself so its a bit early to sell them. Plus after putting the car together with the chassis there are some other things i want to improve/tweak. If all goes well maybe I will. keep you guys posted.
Old 07-20-2025 | 06:44 AM
  #475
Marcos.J's Avatar
Super Moderator
lbsnoopy, mike_G and Kaspurr84 like this.
Marcos.J is offline
Old 07-20-2025 | 07:11 AM
  #476
Leaving this here:https://site.petitrc.com/reglages/mugen/setupmtc3/
LOW ET likes this.
Arn0 is offline
Old 07-20-2025 | 08:55 AM
  #477
Kaspurr84's Avatar
Originally Posted by Marcos.J
Tell us more! Did you make the chassis? Looks great.
Old 07-20-2025 | 09:58 AM
  #478
Marcos.J's Avatar
Super Moderator
Is getting tested by the person that made it , more info coming soon
Marcos.J is offline
Old 07-20-2025 | 04:11 PM
  #479
lbsnoopy's Avatar
Default MTC3 parts
Who or where is the go to for Mugen parts ? Not much available yet for the MTC3 .
Can you even order from the Mugen website ?
Thnx in advance.
lbsnoopy is offline
Old 07-20-2025 | 04:40 PM
  #480
Thnx in advance.
https://www.mugenracing.com/mtc3-1/
Robbob is online now
