MTC3
#616
I have been loving the car so far on mod asphalt. The car is the fastest I have ever seen in tight low speed corners. It rotates predictably and locks in on exit like no other.
Durability is fantastic. I was driving like an idiot and caught the rumble strip in the sweeper sending the car cartwheeling the entire span of the track. The car still finished the run and was minorly out of alignment.
Only parts I would recommend for asphalt is the 4.75 springs for the front, KPA really woke up the front end of the car, and a gauge to properly set up stops and droop is key.
what is KPA?
#622
https://www.sidepieceracing.com/A800...scription=true
#623
R/C Tech Elite Member
#624
Martin Paradis
#625
fyi the mod belt is what Marc now runs on his car along with many of the awsomatix team.
#627
I put a 15 in front and behind the motor plate, then a 10 inline with each of those.
Then a 10 to the left and right of both belts ... in front of the servo and behind the esc/battery
Also stuck a 10 between my rx and fan
Plus I run a 22g SSteel Sortafast battery plate
My idea was to keep them as close to the centerline of the chassis.
I just wish they would lower the weight again, even if it was just 30/40 grams lol
#629
#630
Lots lol
780Likes
