ToolkitRC M8D Charger >
Like Tree131Likes
Old 10-18-2024 | 09:33 AM
  #61
disaster999's Avatar
Regional Moderator
Originally Posted by XCELL
Thinking of purchasing this charger, has a lot of great features and seems that those who have it really like it. I wonder if you could use the RC Discharger system with this charger for the recycle discharge function? May not be possible, but just a thought.
Patrick
Not really sure what RC discharger system you are referring to. Read the thread. Ive mentioned this a few times. You can do regenerative discharge back into a battery or through the internal 40W discharger. There is no other discharging function for this charger, no resister bank, no discharging from one channel to another.
disaster999 is offline
Old 10-18-2024 | 11:26 AM
  #62
The RC Discharger system is designed to be use with ichargers, it allows you to use the regenerative discharge function to discharge into a battery. It is an expensive unit, however I do not think it will work with this charger.
Patrick
XCELL is offline
Old 10-18-2024 | 05:15 PM
  #63
Patrick
If it goes on the power input side of the charger it should work. If it relies on using discharge from one channel to the other, it will not.
biz77 is offline
Old 10-18-2024 | 06:26 PM
  #64
Regional Moderator
Patrick
If all it does is allow it to do regen discharge and still provide AC-DC power to the charger, I dont see how this wouldnt work with the M8D. Its not like the ichargers have some special communication port with this RC Discharger. Im sure all the controls is done on the standalone logic board. But at $330, do you want to risk and and try it.
Old 10-19-2024 | 02:30 AM
  #65
RC discharger is actually doing nothing fancy. He just creates what is mentioned in the manual and with his 3D printer he creates a nice housing on it.
Regenerative Discharger 2S - RC Discharger
Nothing more than a case with a battery and a power supply. And so far I can see he probably did add a BMS for the battery.
Roelof is online now
Old 10-19-2024 | 03:41 AM
  #66
Hi guys, reading your reviews, I ordered one too, can anyone tell me if by updating the firmware there is a risk of losing the precision of the balancer calibration? or are there no problems?
sav13 is offline
Old 10-19-2024 | 07:25 AM
  #67
Regional Moderator
Im sure theres more than "just a BMS for the battery". There must be some logic and voltage and current detection and power switching from battery and AC power. It needs to keep the battery at a low charge all the time in order for it to be ready to accept charge back from the charger and be intelligent enough to switch to AC power when the battery voltage drops too low.
Old 10-19-2024 | 08:37 AM
  #68
A decent BMS with maybe a relay activated by the PSU to switch the battery between a load and the charger can do that, I doubt he has designed an own circuit board doing that.
Old 10-21-2024 | 08:04 AM
  #69
Originally Posted by sav13
Ciao ragazzi, leggendo le vostre recensioni, ne ho ordinato uno anche io, qualcuno mi sa dire se aggiornando il firmware si rischia di perdere la precisione della taratura del bilanciatore? oppure non ci sono problemi?
any opinions from whoever did the update?
sav13 is offline
Old 10-21-2024 | 09:52 AM
  #70
Power supply is always on. BMS is set so that battery is kept at a specific storage voltage and not a full charge, that way there is room in the battery to accept a discharge. Power to charge is provided by the battery until it sags below a predetermined voltage and then the power supply will start providing power to cover the power needs of the charger and get the battery back up to the storage threshold. I'm doing something similar on a much larger scale, albeit less expensive and bulkier, with a 100aH LiFePO battery and small AC charger. This is feeding up to 10 racers running up to 12 charger channels.
disaster999 likes this.
biz77 is offline
Old 10-21-2024 | 07:26 PM
  #71
Just got a M8d today. I was wondering if you guys have changed the "balance start voltage" in the settings. It was taking forever for the charge to end with the default setting.
dway100 is offline
Old 10-22-2024 | 08:50 AM
  #72
That is the biggest complaint I have with the charger right now. Yes, we did update one charger to the 400mV setting, which I believe was as high as it goes for balance start voltage. I did not yet hear back if this helped speed up the final stage of charging however.
biz77 is offline
Old 10-22-2024 | 08:59 AM
  #73
After I posted last night, I lowered it to 10mv and it made a huge difference. It charged at my set amps until a cell hit 4.19 then it slowed down and balanced from there.
STLNLST and biz77 like this.
dway100 is offline
Old 10-22-2024 | 12:57 PM
  #74
This makes sense. Not sure what prompted me to go the wrong direction. We will try this. Thank you.
dway100 likes this.
biz77 is offline
Old 10-23-2024 | 08:35 AM
  #75
Dopo aver pubblicato ieri sera, l'ho abbassato a 10 mV e ha fatto un'enorme differenza. Si è caricato ai miei ampere impostati finché una cella non ha raggiunto 4,19, poi ha rallentato e si è bilanciato da lì.
the default value is 100, what changes and why set it to 10?
sav13 is offline
