Looking for a case that will hold two surface radios. >
Like Tree3Likes
  • 2 Post By billdelong
  • 1 Post By hippo_408
Old 09-17-2024 | 07:13 AM
MiamizFinest's Avatar
Default Looking for a case that will hold two surface radios.
Anyone have any ideas on what i could use?
MiamizFinest is offline
Old 09-17-2024 | 08:05 AM
petersen114's Avatar
Harbor Freight might have something.
petersen114 is offline
Old 09-17-2024 | 08:13 AM
Go to a company specialized in portable stadium equipment. All kind of suitcases in different sized to hold microphones, instruments and all kind of audio/video stuff. Most cases come with picking foam rubber so you can create fitting compartments for the transmitters.
Roelof is offline
Old 09-18-2024 | 06:13 AM
yup, I've been using this one here for many years:
https://www.harborfreight.com/18-in-...ase-69318.html
it fits my power supply, charger and 2 surface radios with pick foam to separate each item though I use NB4 radios which are smaller and easier to fit.
petersen114 and hunterdawg like this.
billdelong is offline
Old 09-18-2024 | 06:19 AM
oldfool's Avatar
Pelican?
https://www.thecasestore.com/shop/case/medium
oldfool is offline
Old 09-18-2024 | 08:17 AM
Thumbs up
That case looks great, I am going to check it out. I have my doubts it will fit tho, your NB4 is much smaller. I would need to put a Futaba 4PX and KO EX-6R in the case. They are THICK BOIS.
Old 09-18-2024 | 11:26 AM
hippo_408's Avatar
harbor freight also has knock off pelican cases with foam blocks, they have 3 or 4 different sizes, i have the large 3800 size (interior dimensions: 14-7/8 in. x 10-5/8 in. x 6-1/8 in.) and i fit my nb4 a charger and all my cables and bluetooth programers in it
they als have an XL 4800 (Interior dimensions: 17-7/8 in. x 12-7/8 in. x 6-1/4 in.) that would probably work for you
https://www.harborfreight.com/4800-w...een-56863.html
petersen114 likes this.
hippo_408 is offline
Old 09-24-2025 | 10:38 AM
Still looking but have not had much luck. Maybe someone has a fresh idea?
Old 09-24-2025 | 11:03 AM
simple's Avatar
Top of the line cases can be found here.
https://www.caseclub.com
Cheaper options here:
https://www.aliexpress.com/
enter search > waterproof hard carry case
I've purchased from both on various occasions - Just depends on how much you value your gear.
simple is offline
Old 09-24-2025 | 01:02 PM
Check out Condition 1. They have many nice cases, but pricey.
hunterdawg is online now
Old 09-24-2025 | 11:39 PM
gigaplex's Avatar
Maybe you can elaborate on your requirements and why none of the previous suggestions were adequate?
gigaplex is offline
Old 09-25-2025 | 01:18 AM
I have to agree with the previous post. Tell us why all given options are nou suitable?
Roelof is offline
