Looking for a case that will hold two surface radios.
Anyone have any ideas on what i could use?
Originally Posted by MiamizFinest
(Post 16127926)
Go to a company specialized in portable stadium equipment. All kind of suitcases in different sized to hold microphones, instruments and all kind of audio/video stuff. Most cases come with picking foam rubber so you can create fitting compartments for the transmitters.
Originally Posted by petersen114
(Post 16127933)
Harbor Freight might have something.
https://www.harborfreight.com/18-in-...ase-69318.html it fits my power supply, charger and 2 surface radios with pick foam to separate each item though I use NB4 radios which are smaller and easier to fit. |
Originally Posted by billdelong
(Post 16128142)
yup, I've been using this one here for many years:
(Post 16128163)
That case looks great, I am going to check it out. I have my doubts it will fit tho, your NB4 is much smaller. I would need to put a Futaba 4PX and KO EX-6R in the case. They are THICK BOIS.
harbor freight also has knock off pelican cases with foam blocks, they have 3 or 4 different sizes, i have the large 3800 size (interior dimensions: 14-7/8 in. x 10-5/8 in. x 6-1/8 in.) and i fit my nb4 a charger and all my cables and bluetooth programers in it they als have an XL 4800 (Interior dimensions: 17-7/8 in. x 12-7/8 in. x 6-1/4 in.) that would probably work for you https://www.harborfreight.com/4800-w...een-56863.html https://cimg8.ibsrv.net/gimg/www.rct...40b78f8938.jpg |
Still looking but have not had much luck. Maybe someone has a fresh idea?
Top of the line cases can be found here.
https://www.caseclub.com Cheaper options here: https://www.aliexpress.com/ enter search > waterproof hard carry case I've purchased from both on various occasions - Just depends on how much you value your gear. |
Check out Condition 1. They have many nice cases, but pricey.
(Post 16215989)
(Post 16215989)
| All times are GMT -7. It is currently 07:06 AM. |
