Team Associated RC8B4 >
Like Tree65Likes
Old 02-09-2024 | 01:58 PM
  #61
nitrous36's Avatar
Moderator
nitrous36 is offline
Old 02-09-2024 | 03:33 PM
  #62
petersen114's Avatar
Originally Posted by nitrous36
Dumb question, but what tires are you running on your setup? I was considering the AKA I beam tires medium/long wear. I might be sacrificing grip but looking for longer tire life.
https://www.amainhobbies.com/aka-ibe...78813?v=450465
Sweep tires have been pretty good to me in both the wear and traction departments over the years. Mainly speaking of their Defenders in yellow and gold compounds.
nitrous36 and MarcMadd like this.
petersen114 is offline
Old 02-14-2024 | 07:28 AM
  #63
I second this. I've been using the defenders in silver compound and they are good in multiple track settings and compound lasts a long time.
nitrous36 likes this.
MarcMadd is offline
Old 04-29-2024 | 07:23 AM
  #64
Any general suggestions on what to change to add initial turn in? My car pushes on corner entry at mid-high speeds on dusty outdoor track.
Chillez is offline
Old 04-30-2024 | 05:22 AM
  #65
Suposing correct tires and suspension setup (keep in mind harder springs makes the car less cornering), several thing to test:
- Thinner front sway bar.
- Thinner front diff oil.
- If the car has understeering when mantaining throttle inside an open corner, try MORE caster (move rearward front upper arm)
- If the car has understeering the first moment is entering corner, try LESS caster (move forward front upper arm)
More things to test, like ackerman or rear-end rotation. But first try steps above.
REMEMBER: each change has a positive effect, and a negative side... that's the difficult part: find balance.
jeancc is offline
Old 04-30-2024 | 12:54 PM
  #66
racing_jason's Avatar
Care to tell us a little bit more about your setup and what the track conditions are? The more info you give us to start the better solution we can give you.
This car, generally speaking, is pretty numb in the front so most of the adjustments are done with the rear of the car.
Look forward to helping you out!
racing_jason is offline
Old 05-02-2024 | 11:07 AM
  #67
Goomba_7's Avatar
Two things that help me adjust the initial turn in on this car has been caster and ackermann. With the caster it was simply just standing the upright up more, instead of laying it back. So putting the adjustment spacers behind the upper arm. With the ackermann it was making the inside wheels open up more. So moving the link towards the rear on the ackermann plate.
This increased the initial turn in off-throttle into the corner. Normally on the brakes as well. You could also put more rear brake in as well.
These are some the first things I play with when I just need a little bit more. Especially if I like the diff setup everywhere else.
racing_jason likes this.
Goomba_7 is offline
Old 04-22-2025 | 06:10 AM
  #68
blonger's Avatar
Originally Posted by racing_jason
You have two options aside from the kit (Stiff) bladders,
Most opt for the emulsion-style bladders
They do sell a softer option of a bladder that i would consider soft.
I personally opt for the emulsion style 90% of the time, bladder style the track would have to be really smooth for me to consider either the stiff or the soft options.
Hope this helps,
Newbie here, what's the difference? Do you need different shock caps? Do you bleed the shocks differently?
blonger is offline
Old 04-22-2025 | 08:00 AM
  #69
Emulsion shocks mix the oil and air together whereas blades shocks have a bladder that separates the oil from the air. The shock caps for emulsion have a bleed screw on the cap whereas the bladder doesn’t.
nitrous36 and blonger like this.
Old 04-22-2025 | 09:06 AM
  #70
As mentioned above emulsion mixes air and oil together.
The emulsion style is less likely to "pack up" which makes it more preferable for tracks with bumps and things like that. They also feel a little less edgy in my opinion.
Down side to them is you are adding air into the system which can makes them less then consistent as they are very much at mother nature's mercy (as it heats up the air expands) so you need to make sure you're bleeding them throughout the day.
Bladder style shocks are a little more consistent run to run (as long as you have them air free) but it's really hard (Or at least for me) to get them to be "Dead" or zero rebound.
The caps that come on all B4's allows you to choose Emulsion or bladder style. Only thing you need is to either use the emulsion seal or the bladder.
To bleed the emulsion style undo the screw in the cap hold the shock at 45° and move the piston up slowly count to five and put the screw back in.
For the bladder (This is how i do it) fill the shock up and slowly start tightening the cap until you feel the bladder come in contact with the top of the shock. Back off the cap 1/4 turn and slowly compress the shock. Once fully compressed tighten the cap. (Make sure you have the bleeder screw in)
I believe youtube has a couple videos about bleeding shocks, onroad shock videos work well for shocks with bladders.
Hope this helps you,
blonger likes this.
Old 10-19-2025 | 08:26 AM
  #71
nitrous36's Avatar
Moderator
Finally! After 2 years of delays and setbacks, she is complete!
Since taking the photos I've set my droop. Can't wait to do a shake down run.
Old 10-20-2025 | 07:54 AM
  #72
Enjoy!
Old 10-20-2025 | 01:26 PM
  #73
DesertRat's Avatar
Do the break in!
You probably knew that but here is a good guide, I kind of like this guys videos:
nitrous36 and petersen114 like this.
DesertRat is online now
Old 10-20-2025 | 01:43 PM
  #74
Looks good. 👍
Old 10-20-2025 | 02:39 PM
  #75
nitrous36's Avatar
Moderator
Enjoy!
Can't wait!
Originally Posted by DesertRat
Do the break in!
Good video. ​​​​I plan too. The engine I bought is already broken in(so they claim, but I still plan to run 3-4 tanks through it to be sure.
Looks good. 👍
Thx!
petersen114 likes this.
