Xray X1 - Formula One Car >
Like Tree366Likes
Old 08-04-2023 | 11:30 AM
  #3166
OMG, Xray is finally including the gear diff on '24 kit 😯
DavidNERODease is offline
Old 08-04-2023 | 11:34 AM
  #3167
Canuck's Avatar
The axle is longer on the X1 2024 Gear diff
Canuck is offline
Old 08-04-2023 | 09:46 PM
  #3168
Dan's Avatar
Dan
And 300 flex adjustments.
Dan is offline
Old 08-15-2023 | 08:48 PM
  #3169
Picked up a X1 2020 and need a good base setup for a small low grip asphalt track. Does anyone have a link to a solid base setup?
Poor_Boy is offline
Old 08-16-2023 | 05:03 AM
  #3170
Default Xray X1 setup
You can try this one's : https://site.petitrc.com/reglages/xr...etsXRayX1.html
Alain Patry is offline
Old 08-16-2023 | 05:43 AM
  #3171
Originally Posted by Alain Patry
Petitrc only has one 2020 outdoor setup and it is for wet condicondtionsions unfortunately.
Poor_Boy is offline
Old 08-16-2023 | 06:30 AM
  #3172
busman's Avatar
Grip is just a matter of perspective, A real chance, Where you run and consider low is quite close to what others consider medium, it’s a place to start and modify from there.
busman is offline
Old 10-20-2023 | 10:49 PM
  #3173
On the Xray setup for 24 X1, what motor is generally ran overseas? 25.5?
Racecarguy is offline
Old 10-21-2023 | 12:49 PM
  #3174
in Europe they mostly run 21.5, if I'm not mistaken
Martin Paradis
MonkeyCmonkeyDo likes this.
rhodopsine is offline
Old 11-05-2023 | 03:35 PM
  #3175
thirtydaZe's Avatar
X1 ‘24.
My ProTek 160tbl wont fit this cars new design.
Anyone know if the ProTek 160ss will squeeze in?
thirtydaZe is offline
Old 11-06-2023 | 07:20 AM
  #3176
Originally Posted by thirtydaZe
X1 ‘24.
Where is the interference? Im running the 160ss in my 23.
perez62682 is offline
Old 11-06-2023 | 03:44 PM
  #3177
TonysScrews's Avatar
X1 ‘24.
I'm having a similar problem with my MTC2 FWD car that I just built. The ProTek 160 servo is not "shallow" enough. Can barely set the gear mesh since the servo is butted up against the motor. Don't want the heat off the motor that close to the servo either.. So I started looking at shorter servos. Looks like the Sanwa PGS LH2 is a few mm shallower, but the MKS servos are very, very short. They're both expensive servos. I know the Sanwa is very popular but don't know much about these MKS servos.
thirtydaZe likes this.
TonysScrews is offline
Old 11-07-2023 | 06:38 AM
  #3178
Dan's Avatar
Dan
Would a servo spacer work inbetween the ears and the servo mount?
Dan is offline
Old 11-19-2023 | 08:58 AM
  #3179
What size bearing fit in these to use on my 24 X1 car?
Old 11-20-2023 | 07:19 PM
  #3180
Anyone have a good asphalt setup for an x1 23/24
racenut123 is offline
