Like Tree886Likes
TLR 22 5.0
Old 06-16-2023, 07:35 AM
  #2671
Pistol123's Avatar
Originally Posted by ThisIsRDG
The TLR press release discusses how the +4mm chassis is best for clay and the +7mm us best for carpet/turf. Can someone explain why the chassis length depends on the surface? I would have thought the length would be more effected by the size of the track and possibly tightenss of the turns. (IE. large high-speed track would be more stable with long chassis, while a small track with tight low-speed turns would benefit from a shorter chassis)
On the B6.2 the longer chassis +3mm comes on the carpet car, it was to try and make the car a little slower to react and therefore easier to drive on very high grip carpet. I assume TLR are thinking the same.
One trade off is it doesn't rotate as quick so in the uk we use the short chassis for outside astro and onside carpet.
ThisIsRDG likes this.
Pistol123 is offline
Old 06-17-2023, 06:04 AM
  #2672
I would love to know what you make of the front end mod, with the gigantic offset. I bet that has been an interesting one if a new car is in the works..
Originally Posted by Frank Root
We just have Dakotah focused on the Nitro Nationals this upcoming week. Also, we are fully committed to getting Dakotah his first world championship this year, and he will spend time at HA before the race.
AntH3001 is offline
Old 08-17-2023, 08:02 PM
  #2673
Default tlr232090 vs tlr332084
TLR232090 for the 22 5.0 AC was discontinued. The only composite internal gears are TLR332084 listed for the 22X-4 diff. Are these compatible with the G2 Diff TLR232101?
shortcut3d is offline
Old 08-20-2023, 09:17 AM
  #2674
Trader Rating: 10 (92%+)
Quick question for my Losi drivers.
I have a Losi 5.0 and Xb2. Losi rear wheels don't work on the Xb2 but the X-ray rear wheels work on the Losi. Off set same will I be narrow or wider by using X-ray rear wheels on a Losi
Ohiorccarpet is offline
Old 09-04-2023, 05:05 PM
  #2675
Default Battery size?
So my local track runs a 17.5 sportsman class with 5 minute heats on a high grip clay surface. What is the optimum battery size for the 22 5.0 in these situations?
C_alan is offline
Old 09-04-2023, 05:11 PM
  #2676
SCRAFAN's Avatar
Trader Rating: 22 (100%+)
I run the same class at Hobby Action in Az and run Trinity White Carbon 4300s, it works well.
SCRAFAN is offline
Old 09-05-2023, 02:14 AM
  #2677
Keep in mind, the HobbyWing Handout Spec Motors we run in 17.5 Sportsman at HobbyAction, are VERY undergeared, and are therefore really easy on battery life. We have even had 10 minutes mains on a couple of occasions with that class, simply because we could.
If he is running a standard 540 size 17.5 motor, the 4300's are OK for a 5 minute main. But anything over 5 minutes, and you will start to feel the sag. Much easier to stick with a 5500 or above, just to stay in the sweet spot of the batteries discharge curve, if you are running an open 17.5 motor with open gearing.
BigBuckORamma is offline
Old 09-05-2023, 08:29 AM
  #2678
Ive been running ProTech 5000mha NIHV batteries charged to 8.4v (this is a local club requirement) in my car, but the new layout has a couple of big jumps that I can only clear about 4 or 5 times before the voltage lag gets me. I'm thinking about running my 6400mha batteries to reduce the voltage lag, but wonder if the extra weight is worth it.
C_alan is offline
Old 09-16-2023, 05:34 PM
  #2679
I don’t have 5.0…what’s new on this world champ proto?
4times is offline
Old 09-17-2023, 10:37 AM
  #2680
TurnNBurn's Avatar
Don’t know that you can call it a “prototype, but here’s what I see:
- A motor plate that is milled differently - the light color caught my eye immediately during the interview
- Rear wing mount is mounted only in the 2 upper points - not sure if that’s an Avid part?
- As Tater mentioned, he’s using the rear 22X-4 arms, with the usual cut to give clearance.
- He also said he was using the 69mm X-bones
- Looks like the standard TLR shocks, but with Avid caps (top and bottom), not to mention the standoffs.
- The clutch plate is also milled differently from the production part.
- Although you can’t really see with the wheels, I wouldn’t doubt if he’s running the front offset mods a lot of drivers do as well.
- He might also be using one of the optional length chassis?
-Looks like a lot of titanium hardware, along with anodized camber links he also mentioned in the interview.
If anything else catches my eye, I’ll edit this post, but it’s definitely not a “brand new” buggy. They said as much throughout the week.
TurnNBurn is offline
Old 09-17-2023, 10:43 AM
  #2681
We maybe got an answer on this one....
AntH3001 is offline
Old 09-17-2023, 11:01 AM
  #2682
Trader Rating: 19 (100%+)
Still no easy access diff,that’s the biggest complaint
speed101 is offline
Old 09-17-2023, 11:12 AM
  #2683
Im hoping this was just an research and test exercise, redesigning the diff housing doesn't necessarily correlate with changes needed to make a competitive chassis. Thats a Solid Works project after the fact. TLR would have to be just clueless at this point to release a buggy in 2024 without quick diff access.
AntH3001 and Rcdad42 like this.
Kaspurr84 is offline
Old 09-17-2023, 12:15 PM
  #2684
hairymuffin's Avatar
Trader Rating: 105 (100%+)
I wonder if the fantom motor and batteries are not roar approved? As to why he’s not running all fantom products. I know I heard this was the case with Trinity Phend’s equipment… seems like it shouldn’t really matter with mod motors
hairymuffin is offline
Old 09-17-2023, 02:36 PM
  #2685
ChocoTaco73's Avatar
They are ROAR approved just not IFMAR approved.
ChocoTaco73 is offline
