Sanwa-compatible receiver thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree130Likes
Last edit by:
Print Wikipost
Old 08-16-2023 | 11:52 AM
  #301
They advertise right on the case that the receiver is Ant free, but mine came with a huge cockroach!
glennhl is online now
Old 08-16-2023 | 04:30 PM
  #302
Marcos.J's Avatar
Super Moderator
lol mine doesn’t have an antenna
Marcos.J is offline
Old 08-16-2023 | 04:52 PM
  #303
choisan's Avatar
Originally Posted by sawzall
Had a chance to try out a DasMikro FHSS-5 receiver. Used it in FH5 mode will SSL with a PGS-CX2 servo and CODE10 worked as expected. I also tried it with SXR in FH5U mode and it also worked fine (I honestly can't tell the difference between SUR and SXR). I didn't experience any signal loss, clipping or other oddities. I also compared its range to a real Sanwa 492i, and it was pretty much the same. I haven't tried FH5U with the PGS-CX2 in the SSL port, but I'll try it over the weekend.
I'll still run original Sanwa receivers in my competition cars, but this looks like a nice alternative for bashers and some of my 'fun' chassis.
oh, that is good to know yours working in ssl, did you set the servo with different racing steering modes (parameter)? can you share what you set code10?
too bad that mine not working,.........
choisan is online now
Old 08-16-2023 | 07:04 PM
  #304
I didn’t have a lot of time to set things up, so I only played with DBAND. That’s a pretty easy way to see if SSL is working.
sawzall is offline
Old 08-25-2023 | 05:38 AM
  #305
There's a new Sanwa compatible receiver coming out! Looks like it might be a rebranded Das Mikro - https://www.redrc.net/2023/08/takash...s/#more-214127.
sawzall is offline
Old 08-26-2023 | 05:53 AM
  #306
There is review on Sanwa original RC-492i compared to DasMikro FH5 RX on youtube.
https://youtu.be/LRrRNc7iaj0
sangyue is offline
Old 08-27-2023 | 04:53 PM
  #307
choisan's Avatar
the video didnt show the PGS-XRII servo "PLUGGED" into the SSL socket in the receiver and change the preset "setting" on the fly from the transmitter. it just shows setting the servo in transmitter for 1 setting ONLY.
please kindly advise if i missed any. thanks
Old 08-30-2023 | 06:09 AM
  #308
I noticed there is a V2 of the FH5 receiver from Das Mikro. I perused the last bit of this thread and didn't see if the discussion is V1, V2 or both? Curious if V2 corrected the issues that were present in early versions. I need to order some of their FH4 receivers so if things are looking up, I'll add an FH5 to the order.
Silverbullet555 is offline
Old 08-30-2023 | 07:56 AM
  #309
gigaplex's Avatar
My one that has brownout issues is the original version.
Silverbullet555 likes this.
gigaplex is offline
Old 08-30-2023 | 04:44 PM
  #310
choisan's Avatar
oh, how to tell which is v1 or v2? i guess my unit is v1.
Old 08-30-2023 | 05:43 PM
  #311
gigaplex's Avatar
The case looks different.
V1
V2
gigaplex is offline
Old 08-30-2023 | 11:10 PM
  #312
And that also means it is technically different?
Roelof is offline
Old 08-30-2023 | 11:56 PM
  #313
gigaplex's Avatar
Probably. Not sure whether the internals are changed or whether there's a difference in capabilities, seems odd they've got both in quick succession. The V2 case looks like a pretty blatant copy of the RX-492.
gigaplex is offline
Old 08-31-2023 | 07:27 AM
  #314
jasburrito's Avatar
Default Negative
All relievers have neg on outside besides v1. V2 has neg on outside. I have 6 fake receivers. They all work fine.
jasburrito is offline
Old 08-31-2023 | 07:51 PM
  #315
choisan's Avatar
this is what i thought and i am asking for exchange for the v2.
normally it is considered major change in term of technical after such a short product launch
