Sanwa-compatible receiver thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree130Likes
Last edit by:
Print Wikipost
Old 07-27-2023 | 05:07 PM
  #286
choisan's Avatar
Originally Posted by Silverbullet555
gigaplex and choisan thanks for being a guinea pig on these. Would love to find some lower priced FH5 for a few of the "non"essential cars as I'm sure others would too. Hopefully the voltage issue is simply a bad unit.
to be honest, the price difference of this clone to a sanwa original, say 493i, is just slightly half in some places elsewhere. i would go for the genuine for my next purchase as my servo is sanwa's PGS and i want to play around the SSL.
choisan is offline
Old 07-28-2023 | 05:33 AM
  #287
I appreciate the honesty. Glad they are trying to figure it out. Sounds like there is still some work to do.
Where these fit in is in a few smaller 1/18th scale oval cars that can't run any of the SSL stuff. I've noticed (unrelated to the clone) that when switching from an FH4 receiver car to an FH5 receiver car on the radio, the 4 will have a blip of throttle if it is still on. The car is left on after a race to allow the fans to cool it while I am in another race. Anyway, id like to prevent that little blip by having all my oval cars on FH5 receivers.
Once again, thank you for being a tester and reporting back. I'll continue to follow.
choisan likes this.
Silverbullet555 is offline
Old 07-28-2023 | 09:42 AM
  #288
Originally Posted by gigaplex
I used my multimeter and observed voltage dips down to 5.5V before it cut out. The older receiver didn't cut out despite dipping to 5.4V. Dasmikro lists the operating voltage range as down to 3.5V so either it's failing to meet that, or the multimeter can't measure the spikes fast enough.
nothing related with the topic being discussed, but how much voltage should be supplied by the bec? Recently I dicovered that when I move the servo very quickly (with original sanwa rx472) the motor fan speed drops for a while and returns to normal, maybe the bec is weak or inadequate. I think this also answers about why my lap counter suddenly turning off
b.wihardja is offline
Old 07-28-2023 | 09:58 AM
  #289
DirkW's Avatar
Most BECs supply 6.0V nowadays. Often you can increase this up to around 7.2-7.4V for quicker and more powerful servo movements - but if your electronics are not rated for such higher voltage, they can get damaged (at least over time).
sangyue and gigaplex like this.
DirkW is offline
Old 07-28-2023 | 11:47 AM
  #290
I'd love to try one of these copy receivers, but I'd like to see some data that shows they are just as fast as stock Sanwa's. Does anyone have some data?
glennhl is offline
Old 07-28-2023 | 08:05 PM
  #291
Normally if it is a clone, then it should be as fast as stock Sanwa's. If it is a redesigned(software) compatible receiver, then we need some test data...
sangyue is offline
Old 07-29-2023 | 03:31 AM
  #292
choisan's Avatar
if it is a clone and talking about a "clone", it is not an identical clone, at least, the SSL with Sanwa PGS HR servo on FH5U is faulty. then someone may doubt if it is as fast as genuine.
choisan is offline
Old 07-29-2023 | 08:09 AM
  #293
As I know in FH5U mode telemetry function and SSL port are all disabled. There is a supplementry manual from Sanwa official wesite. Below is the screen shot from page 2.
Link: SANWA
You can only find the pdf document in Japanese language, in English language I cann not find it.
gigaplex likes this.
sangyue is offline
Old 07-29-2023 | 10:12 AM
  #294
choisan's Avatar
well noted for the info, then i shall try SSL with FH5 SUR for the PGS Servo if i dont misinterpret the manual.
choisan is offline
Old 07-29-2023 | 02:39 PM
  #295
gigaplex's Avatar
Have you had SSL working on a genuine Sanwa receiver?
gigaplex is offline
Old 07-30-2023 | 12:44 AM
  #296
choisan's Avatar
Default Bench testing on Sanwa PGS servo
yes, i do have a genuine sanwa 491 by FH5, SSL, SUR moded PGS XRII in my Infinity IF18-2 and XR in my MRX6X, however, tried FH5, "SSL" SSR PGS HR didnt work, FH4T "SSL" SSR PGSHR didnt bind.
my self funded quality assurance for this "clone" in terms of Function Test , SIT and UAT are done which just ONLY works in FH5U, SXR PGS HR.
With that said, no real response test on the working mode for my existing HR servo can be made per my human perception.
above for reference and viewer discretion only.
choisan is offline
Old 07-30-2023 | 08:09 PM
  #297
jabroni racing's Avatar
ran my close i got off amazon for $55 today, No Issues 4wd 13.5 buggy.
https://www.amazon.com/dp/B07PG6651Q...roduct_details
jabroni racing is offline
Old 08-14-2023 | 11:02 PM
  #298
gigaplex's Avatar
Any other feedback from anyone trying the FH5 clones? My replacement unit was lost in transit, so it might be a while before I can try another.
FH4T won't bind, receivers support FH4 or FH5, not both.
gigaplex is offline
Old 08-16-2023 | 10:04 AM
  #299
Had a chance to try out a DasMikro FHSS-5 receiver. Used it in FH5 mode will SSL with a PGS-CX2 servo and CODE10 worked as expected. I also tried it with SXR in FH5U mode and it also worked fine (I honestly can't tell the difference between SUR and SXR). I didn't experience any signal loss, clipping or other oddities. I also compared its range to a real Sanwa 492i, and it was pretty much the same. I haven't tried FH5U with the PGS-CX2 in the SSL port, but I'll try it over the weekend.
I'll still run original Sanwa receivers in my competition cars, but this looks like a nice alternative for bashers and some of my 'fun' chassis.
sawzall is offline
Old 08-16-2023 | 10:31 AM
  #300
Marcos.J's Avatar
Super Moderator
I have been using the FH5 clone for a while it works just fine no issues with it
Marcos.J is offline
