Sanwa-compatible receiver thread
#256
I have no problem with FH5U. SSR servo in SXR mode also works fine. Try to bind it again.
Sanwa FH-5 related user manuals:
https://drive.google.com/drive/folde...z-?usp=sharing
#260
I bought one too, and the socket slot can't govern the plugs to be reverse, my friend said wrong plug inserting (reverse) will not ruin the receiver.
can't expect more from such a bargain, i used SSL servo and can't use on FH5(U), but SSL on FH4T is ok, at least the servo will move.
#261
#263
Some of the Sanwa receivers are waterproof despite having a very leaky case. A conformal coating on the PCB should be all that's required. And this clone can prevent reverse plugging for Futaba style connectors with the side tab, it has the opening.
#264
Update on my unit. After 2 laps I got a massive radio glitch. Nearly wrote my car off. Won't be trying this one again.
#265
#268
Transponder was a reasonable distance away from the receiver and all wires are in good condition.
#269
#270
130Likes
