Sanwa-compatible receiver thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree130Likes
Last edit by:
Print Wikipost
Old 10-13-2023 | 06:59 AM
  #331
choisan's Avatar
Originally Posted by gigaplex
I wonder what they've done to cut the price on that one.
with telemetry but the temp and rpm sensor features were taken away which is said to use with the sanwa's esc (super vortex)at this moment, i guess they just disable the function in the "ic"
choisan is offline
Old 10-15-2023 | 09:41 AM
  #332
rustyus's Avatar
Default Lowest Price I've Seen
Originally Posted by jabroni racing
i have 3 of these off amazon, NO issues.. ARX-482R 4CH FHSS
https://www.amazon.com/ARX-482R-Inte..._0_1_ec_i&th=1
I debating on getting more of them after seeing this...
rustyus is offline
Old 10-20-2023 | 02:13 PM
  #333
Telemetry is such a sad joke. Is there any RPM or temperature that works with a 493 without a Sanwa ESC? I didn't do enough research on the telemetry part it's still a sore spot.
gigaplex likes this.
mrkab is offline
Old 10-22-2023 | 06:36 AM
  #334
That is tempting.
jabroni racing likes this.
Silverbullet555 is offline
Old 11-05-2023 | 07:32 AM
  #335
lbsnoopy's Avatar
Default M11X and M12S
So , I have and like the older Sanwa radios , what receiver would be best for both ? The 481 or the 482 ?
Also , the lipo battery fail safe issue with these , I shouldn’t have to worry about that as you can program your lipo cutoff in your esc , correct ?
The m11x I haven’t used in years and just picked up the m12s , thus the reason for the questions, I’ve been using a different remote for my off-road stuff and would like to use one of the 2 sanwas for my onroad cars . Thnx in advance .
lbsnoopy is offline
Old 11-05-2023 | 09:39 AM
  #336
rustyus's Avatar
I don't know of any non-genuine Sanwa compatible receivers labeled as a "481".
rustyus is offline
Old 11-05-2023 | 10:09 AM
  #337
lbsnoopy's Avatar
Default Rx481
lbsnoopy is offline
Old 11-05-2023 | 10:50 AM
  #338
jabroni racing's Avatar
i think you misunderstood the previous response, this thread is for the Non sanwa receiver, basically the knock offs they wont label them with sanwa numbers such as 481 or 482, just fh3 or fh4 for example. .. if your looking for a fh4 or fh3, you can search for the knock offs.
lbsnoopy likes this.
jabroni racing is offline
Old 11-05-2023 | 11:42 AM
  #339
lbsnoopy's Avatar
Default Reply
THNKU jabroni , I did misinterpret, wrong thread I guess .
lbsnoopy is offline
Old 11-05-2023 | 12:53 PM
  #340
gigaplex's Avatar
Knock offs regularly do use the 482 number though.
Goof and Silverbullet555 like this.
gigaplex is offline
Old 11-25-2023 | 03:44 AM
  #341
gigaplex's Avatar
My Dasmikro 492 v2 clone arrived today. It has the same issue as the previous one, radio brownouts on my car with a weak BEC. My genuine Sanwa FH5 receivers as well as my 482 clones all handle the same test just fine.
gigaplex is offline
Old 11-25-2023 | 04:46 AM
  #342
Still loving mine, run 2wh, 4wh and 1/8, still not one issue :-) Never tried Dasmikro though.when i find something that works i stick with it
Old 11-25-2023 | 05:04 AM
  #343
gigaplex's Avatar
Are any of yours FH5? As far as I know Dasmikro are the only ones that have cloned FH5 so far. And the FH4 ones are solid, that's not an issue. It's specific to the FH5 models.
gigaplex is offline
Old 11-25-2023 | 12:30 PM
  #344
rustyus's Avatar
gigaplex, what particular ESC are you thinking has a weak BEC?
rustyus is offline
Old 11-25-2023 | 12:45 PM
  #345
gigaplex's Avatar
Hobbywing Justock XR10 (not the G3 variant).
gigaplex is offline
