Like Tree11Likes
  • 4 Post By Roelof
  • 1 Post By Manning
  • 1 Post By Roelof
  • 3 Post By Roelof
  • 2 Post By DirkW
EPA 150%
Old 03-16-2023 | 11:08 AM
Default EPA 150%
The throttle and brake EPA on my Tx can go as high as 150%. should I keep it at 150% when programming my ESC?
buggybug is offline
Old 03-16-2023 | 11:49 AM
No, just 100%
Roelof is online now
Old 03-16-2023 | 03:20 PM
Thanks!
buggybug is offline
Old 03-17-2023 | 11:40 AM
By calibrating at 150% you will increase the precision when adjusting the EPA and brake strength, however this won't increase the level of output.
If you find that making 1% adjustment on a 0-100% scale is too big of an adjustment, then that's where the 150% trim settings can come in handy.
billdelong is offline
Old 03-17-2023 | 04:12 PM
gigaplex's Avatar
This is true if you use EPA to dial out the brakes, but if you use the dual rate instead you won't see that benefit. On most radios I've seen, the dual rate adjustment is quicker to do so it gets used more often.
gigaplex is offline
Old 03-17-2023 | 04:27 PM
I always calibrate with the max value of the radio (120, 125, 150) for the go side, but always calibrate with 100% on the whoa side. I never reduce the go side, but occasionally reduce the brakes. It's easier to think about a 100 scale instead of whatever the max value may be.
Manning is offline
Old 03-17-2023 | 04:29 PM
gigaplex's Avatar
Why do you calibrate with a higher EPA on the go side?
gigaplex is offline
Old 03-17-2023 | 04:58 PM
Same as what billdelong said. Theoretically more resolution. Theoretically. It's there, so why not?
Manning is offline
Old 03-17-2023 | 06:03 PM
gigaplex's Avatar
Except billdelong was talking about resolution of adjustments, which you've explicitly said you don't do on the throttle. And you don't use the increased resolution on the brakes which you do adjust. It would make more sense to use max EPA on both, and use DR to tone down the brakes.
gigaplex is offline
Old 03-17-2023 | 08:22 PM
OK, I"m crazy.
gigaplex likes this.
Manning is offline
Old 03-18-2023 | 12:49 AM
Theoretically.....
Most transmitters and ESC's today work with at least a 12 bit resolution, that are 4096 steps. On a 100% EPA setting that is about 2700 steps, on only the throttle that will be 1350 steps. Is your finger that accurate that you can move one step?????? And will you nitice it?
Old 03-18-2023 | 10:45 AM
1995 Monster T's Avatar
Esc should be calibrated above 125% forward on most radios. No need to go to the max.
1995 Monster T is offline
Old 03-18-2023 | 11:44 AM
Should or can?
Yes it can but should not!
mrreet2001, belewis01 and gigaplex like this.
Old 03-18-2023 | 12:54 PM
DirkW's Avatar
At least people no longer claim that your car will run faster if you calibrate your ESC with EPA at 100% and then increase it to 150% after. Don't expect too much.
Riketsu and gigaplex like this.
DirkW is offline
