Like Tree178Likes
Futaba 10PX
Old 01-30-2023 | 04:14 PM
  #241
gigaplex's Avatar
Originally Posted by oldfool
Are all the top shelf radios still using pots?
Seems to me hall sensors would be a no brainer.
I know the M17 has a pot. Unsure about the 10PX.
gigaplex is offline
Old 02-04-2023 | 10:46 AM
  #242
Has anyone heard if a 10PX R or Limited will be released?
madjack is offline
Old 02-04-2023 | 11:49 AM
  #243
It is a whish of thoughts because from most transmitters there was an R follow up.
But why? is the 10PX not good enough?
gigaplex likes this.
Roelof is offline
Old 02-04-2023 | 08:15 PM
  #244
Correct, currently own a 7PXR and was wondering if an R version of the 10PX was a possibility as I'm due for a replacement.
madjack is offline
Old 02-04-2023 | 08:21 PM
  #245
madjack is offline
Old 03-09-2023 | 12:32 PM
  #246
I haven’t heard any news of R model but they seem to usually do an R or limited edition version. I’m sure there will be a new version just not sure when. Currently own a like new 7PXR and looking to possibly upgrade myself.
Buddasmurf is offline
Old 03-10-2023 | 02:12 PM
  #247
Kaspurr84's Avatar
What 10ch receivers are compatible? The manual says s-fhss for 7ch, and f-4g for 10ch. I can’t find any 10ch receivers
Kaspurr84 is offline
Old 03-10-2023 | 03:13 PM
  #248
And the manual also mention that the rest of the channels are only available through SBUS so you need SBUS servo's or an SBUS to PWM channel(s) converter.
Roelof is offline
Old 03-10-2023 | 11:36 PM
  #249
Really? I thought this is necessary only if receiver have 4 channels. Which page in the manual you find that information?
FolioHattu is offline
Old 03-11-2023 | 02:35 AM
  #250
Book_10PX_ENG_Letter.pdf (futabausa.com)
Page 8....
In S-FHSS mode you can use an 8ch receiver, I belive the R2008GF then you only need the sbus direct servo's or converter to connect those last channels. In T-FHSS and F-4G mode you are limited to the 4 channels and the other 6 can be connected by the SBUS. On Amazon, Aliexpress and Banggood you can find all kind of SBUS to PWM converters but also Futaba sell programable ones.
Roelof is offline
Old 04-09-2023 | 09:07 AM
  #251
Brit_racer's Avatar
I am trying to switch from stick (UK racer) to steerwheel. I’ve tried before and wasn’t patient enough. Has anyone had any experience with which video games that this is meant to work with? This might help the switch.
Brit_racer is online now
Old 04-09-2023 | 08:57 PM
  #252
works great with VRC. I needed to go > 100 epa on throttle and steering, but once that was sorted it worked really well.
alpine9000 is offline
Old 04-12-2023 | 03:09 AM
  #253
Does anyone know how to reset the uptime timer? Can’t find it in the manual. In my 4PK and 4PX it can be reset by pressing + and - together but there are no such buttons on the 10PX
breyton is offline
Old 04-12-2023 | 03:42 AM
  #254
On page 56 and on page 177 there is something written about the timer.
breyton likes this.
Roelof is offline
Old 04-12-2023 | 09:21 AM
  #255
Thanks Roelof the info I needed was on page 56
Regarding the touchscreen issues after calibrating posted earlier, I did encounter worse accuracy and response after calibrating. Good thing I programmed the menu to the ES1 button and the display screen to ES2 before calibrating in case I encounter any issues. I then used a stylus instead of my finger to do the calibration and now the touch functionality is perfect.
breyton is offline
