Futaba 10PX
#226
I am having a very weird bug. Going to the user menu and playing with options like throttle endpoint and steering curves will cause the transmitter to shut down roughly half the time. This is a recurring issue. Batteries seem fine and transmitter works perfectly otherwise. It is practically brand new.
Anyone else have any issues like this?? Pretty strange bug…
#228
#229
Can the 10PX set the channel directly to one of these s.bus Decoders?
https://www.frsky-rc.com/product/sbus/
It does not seem to work for me. When I read via the direct connection, the LEDs on the decoder blink real fast but the 10PX always says it did not discover anything. I also tried it on CH1 of a R304SB but got similar results. It would seem this decoder should look just like an s.bus servo to the transmitter.
My next step was to buy a Futaba SBC-1 but it seems like this should work.
Thanks for any tips. This is the first time I have worked with s.bus.
#230
Futaba has a same module you can program through the program port of the transmitter.
#231
which is better for the 10px 7.4v lipo battery or 6.6v life battery
#232
For performance there is no difference.
The original LiFe battery can be charged with a Futaba charger through the charger port because of an own integrated balancer circuit.
LiPo has more capacity
LiPo is less safe
So it is your choice.....
LiPo is less safe
#233
This is the reason why I'm looking at the flysky noble4 pro It can use up to 12 channels before I I need to use the i-bus for 6 more channels max 18 channels. I don't need all that junk on a radio that I will never use.
#234
You answered your own question. You need a s-bus servo to add channels above 4. The manual show how to program the servo. This is why I hate Futaba. You have to buy expensive special servo to get more channels.
smanders
Microsoft Word - SBUS Decoder.doc (frsky-rc.com)
It says it can be programmed by the Futaba SBC1, that is an external programmer. Then I would say the transmitter would also be able to prgram it.
Otherwise you can look at this:
Jhemcu spp 8ch signal converter module support sbus ppm pwm output for receiver Sale - Banggood.com
No programming needed but it does just put out all channels like a normal receiver.
If speed is no issue you can also take a look to the S-FHSS receivers which can be found up to 8 channels
TxRxList_Updated-RX-HIGHLIGHTED (futabausa.com)
#235
To simplify, I ended up just going with a Futaba R2106GF receiver. This gets me 6 channels in analog mode. It works with all servos, no special configuration. Since this is just for a crawler, the response times are not really that important and the price is very reasonable.
#236
I have an issue with my steering holding center. It will randomly move off center and I have to adjust my sub-trim up/down by 20 - 40 before my races. I have tried 3 different servos and I still have this problem.
Could this be an issue with the 10px or receiver? I purchased it new when it came out. I tried creating a new model and that didn't fix it.
Any ideas?
Any ideas?
#237
Any ideas?
Any ideas?
#238
Any ideas?
Any ideas?
#239
#240
I did read somwhere Futaba has the optop or is switching over to electronic pots.
