Like Tree178Likes
Futaba 10PX
Old 10-06-2022 | 10:11 PM
  #226
I am having a very weird bug. Going to the user menu and playing with options like throttle endpoint and steering curves will cause the transmitter to shut down roughly half the time. This is a recurring issue. Batteries seem fine and transmitter works perfectly otherwise. It is practically brand new.
Anyone else have any issues like this?? Pretty strange bug…
smirkracing is offline
Old 10-07-2022 | 05:29 AM
  #227
Originally Posted by RevolutionM
Seems like some things indicate the 10Px comes with both the regular and large wheel other things make it sound like it only comes with one anyone confirm
My 10px came with both small and large wheels, USA bought.
malkiy is offline
Old 11-10-2022 | 05:55 AM
  #228
I have not seen or heard of this issue. I suggest opening up a Tech support ticket with Futaba USA.
c.edwards is offline
Old 11-17-2022 | 11:14 PM
  #229
smanders's Avatar
Can the 10PX set the channel directly to one of these s.bus Decoders?
https://www.frsky-rc.com/product/sbus/
It does not seem to work for me. When I read via the direct connection, the LEDs on the decoder blink real fast but the 10PX always says it did not discover anything. I also tried it on CH1 of a R304SB but got similar results. It would seem this decoder should look just like an s.bus servo to the transmitter.
My next step was to buy a Futaba SBC-1 but it seems like this should work.
Thanks for any tips. This is the first time I have worked with s.bus.
smanders is offline
Old 11-18-2022 | 09:17 AM
  #230
Futaba has a same module you can program through the program port of the transmitter.
Roelof is offline
Old 01-17-2023 | 01:28 AM
  #231
which is better for the 10px 7.4v lipo battery or 6.6v life battery
peter. is offline
Old 01-17-2023 | 03:12 AM
  #232
For performance there is no difference.
The original LiFe battery can be charged with a Futaba charger through the charger port because of an own integrated balancer circuit.
LiPo has more capacity
LiPo is less safe
So it is your choice.....
Roelof is offline
Old 01-17-2023 | 07:24 AM
  #233
1995 Monster T's Avatar
You answered your own question. You need a s-bus servo to add channels above 4. The manual show how to program the servo. This is why I hate Futaba. You have to buy expensive special servo to get more channels.
This is the reason why I'm looking at the flysky noble4 pro It can use up to 12 channels before I I need to use the i-bus for 6 more channels max 18 channels. I don't need all that junk on a radio that I will never use.
1995 Monster T is offline
Old 01-17-2023 | 08:46 AM
  #234
You are very ignorant aren't you? Maybe you should step out of your own world and learn something.
smanders
Microsoft Word - SBUS Decoder.doc (frsky-rc.com)
It says it can be programmed by the Futaba SBC1, that is an external programmer. Then I would say the transmitter would also be able to prgram it.
Otherwise you can look at this:
Jhemcu spp 8ch signal converter module support sbus ppm pwm output for receiver Sale - Banggood.com
No programming needed but it does just put out all channels like a normal receiver.
If speed is no issue you can also take a look to the S-FHSS receivers which can be found up to 8 channels
TxRxList_Updated-RX-HIGHLIGHTED (futabausa.com)
petersen114 likes this.
Roelof is offline
Old 01-18-2023 | 11:39 AM
  #235
smanders's Avatar
To simplify, I ended up just going with a Futaba R2106GF receiver. This gets me 6 channels in analog mode. It works with all servos, no special configuration. Since this is just for a crawler, the response times are not really that important and the price is very reasonable.
smanders is offline
Old 01-29-2023 | 09:56 AM
  #236
I have an issue with my steering holding center. It will randomly move off center and I have to adjust my sub-trim up/down by 20 - 40 before my races. I have tried 3 different servos and I still have this problem.
Could this be an issue with the 10px or receiver? I purchased it new when it came out. I tried creating a new model and that didn't fix it.
Any ideas?
dmaxlb7 is offline
Old 01-29-2023 | 03:08 PM
  #237
gigaplex's Avatar
Any ideas?
First thought is maybe the steering potentiometer is failing.
gigaplex is offline
Old 01-30-2023 | 04:18 AM
  #238
sosidge's Avatar
Any ideas?
Is the servo horn a good fit on the servo? Is it slipping or jumping a spline in crashes?
sosidge is offline
Old 01-30-2023 | 04:54 AM
  #239
oldfool's Avatar
Are all the top shelf radios still using pots?
Seems to me hall sensors would be a no brainer.
oldfool is offline
Old 01-30-2023 | 06:09 AM
  #240
I did read somwhere Futaba has the optop or is switching over to electronic pots.
Roelof is offline
