Like Tree59Likes
iCharger DX8
Old 10-01-2024 | 12:07 PM
  #136
Originally Posted by moulip
All right thank you for your answer. The tire warmer needs roughly 9A. So indeed this should do it.
Does cycling at 30A make a huge difference compared to 40 ?
No, the small gain of a high current charge compared with a normal like 2C charge can only bet noticed if you can run a heat/final flawless, one mistake and the gain is gone. The difference between 30 and 40A will be much smaller. It is also depending the battery, if you use 4200mAh shorties or 8500mAh normal size packs.
Roelof is offline
Old 10-01-2024 | 01:01 PM
  #137
I'm using 2s lipo stick with 6300 mAh.
moulip is offline
