? On motors and timing.
So I have two different brands of motors both 21.5t. Both top out at about the same rpm. But one brand is tuned to 52 degrees of timing the other is at 43 degrees of timing. Same amp draw. Will the one with lower timing have more torque?
The torque would depend on the overall build of the motor. What motors are they, what is the RPM, and what is the current draw?
Which one had the biggest amp jump from being one or two degrees down? The biggest difference would be the kV. The problem with the Sky RC doesn't have a power regulator, so each motor was seeing a different voltage. Either way, it is almost impossible to tell which one has the most torque by looking at the RPM, current, and kV. Knowing the strength of the rotor would help break the tie. Also, this is the exact reason why WMH Racing made the Load Master.
One thing you could do is, run the tests while the motor is installed in your car. The car's drivetrain will add resistance. The car that has the less current draw will be the one with the most torque.
So on paper timing will not mean anything. So if thr rpm voltage and amp draw are the same they should be even. the torque is made up in the measurements on the rotor. And I think that is meessured in Gass if I remember correctly.
Here is a video where I explain a little more about the performance differences.
I have used an EMF Meter similar to this to read rotor strength:
I physically removed the rotor and slowly rotated the rotor as close to the meter and had it lock onto the max reading.
I found disparity between rotors of the same brand and learned to cherry pick the stronger rotors using the EMF Meter
Note that these cheaper EMF Meters can only read 540 sized rotors, I tried it on a 550 SCT motor and it maxed out
A strong rotor is a good place to start, but it doesn't always mean the motor will have a lot of torque. The HW G4r, I just recently tested, had a 1765 rotor. That is very strong. However, under a load, it didn't fair very well with torque.
4Likes
