Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 01-24-2022 | 11:50 AM
  #11011
NutDriver's Avatar
Default BMW M4
Has anyone heard any rumblings about a BMW M4 GT3 body coming in the near future?
NutDriver is offline
Old 01-24-2022 | 12:12 PM
  #11012
bmwjoon's Avatar
A new M4 body would be awesome.
Side note can someone point me to where some info is on the USGT tires. I ran my car Saturday and found basically when I sauced my tires the car was very balanced and easy to drive to when I tried less “saucing” a car that was very loose and unstable. I don’t think I’ve ever driven a tire where the balance change was so dramatic before.
bmwjoon is offline
Old 01-24-2022 | 05:39 PM
  #11013
RCFREAK's Avatar
Myron,
Did the new Type A body get approved yet? I have not see any announcement. Looks real nice.
RCFREAK is offline
Old 01-24-2022 | 05:41 PM
  #11014
I sauce the entire contact patch of the rear and like an 1/8" of the inside of the front.
timberline97 is offline
Old 01-27-2022 | 09:56 AM
  #11015
British Menace's Avatar
Default Traction Roll
I have not ran USGT as yet. Just building a car for it now.
I have a question. Do any drivers suffer from traction roll with these USGT tires we are required to use?
Just wondered what amount of grip to expect.
Regards
BM
British Menace is offline
Old 01-27-2022 | 10:02 AM
  #11016
Regards
BM
On black carpet you will want to glue the sidewalls. Grip is good on black carpet.
V8 Rumble is offline
Old 01-27-2022 | 10:12 AM
  #11017
Right ok. Thanks for the heads up. Do you end up glueing the sidewalls on front and rear tires?
Regards
BM
Old 01-27-2022 | 10:39 AM
  #11018
Just front tires works for me.
glennhl is offline
Old 01-27-2022 | 10:57 AM
  #11019
messn03's Avatar
Default Exotek USGT Corvette
Earnhardt Tribute
Tamiya TT02 spec racer..
Thanks for looking
timberline97, egalsim and glennhl like this.
messn03 is offline
Old 01-27-2022 | 11:00 AM
  #11020
messn03's Avatar
Originally Posted by messn03
Earnhardt Tribute
Thanks for looking
they started out with the tt02 bone stock, then we could put the rubber tires on and a bearing kit. Haven't reached the class yet oh, now I'm reading how the real usgt guys do it. Is there anywhere in Michigan that runs this class? Thanks guys and gals! Mess
messn03 is offline
Old 01-27-2022 | 11:46 AM
  #11021
OSherman's Avatar
Regards
BM
Traction roll is possible depending on surface, tire prep etc.. Very complicated question to answer
OSherman is offline
Old 01-27-2022 | 11:51 AM
  #11022
Mr. McGoo's Avatar
Regards
BM
Any tire on any car can traction roll. So with wrong setup, yes it will. With correct setup, car can be dialed. Once your car is built and you are struggling, post up the setup here and I am sure everyone will be more than happy to help get you dialed in. But as others said, you have to glue the sidewalls of the tire on black carpet for sure.
Rick Vessell and Marcos.J like this.
Mr. McGoo is offline
Old 01-27-2022 | 12:45 PM
  #11023
Regards
BM
Old 01-27-2022 | 01:30 PM
  #11024
Mr. McGoo's Avatar
Regards
BM
Just the fronts
https://www.youtube.com/watch?v=nb8p6z33z3A
Old 01-27-2022 | 04:17 PM
  #11025
bmwjoon's Avatar
I glued my fronts all the way up the sidewall to the crest. On black carpet it only rolled 1-2 times and only if I heaved it into a hairpin with too much energy and steering input.
Rick Vessell likes this.
bmwjoon is offline
