USGT
#9511
I should have mentioned we plan on using these at a local outdoor asphalt track once, possibly twice a month during nice weather. Not in our normal parking lot. Some of the guys want to buy really nice T/C's for this.
What difference are you speaking of Billy? Is it anything like when I took the Tamiya gears out of my FF-03 and installed standard 48 pitch gears? The car is noticably quicker than a friend's stock FF-03. The FDR in both cars is extremely close.
#9513
Just finished reading all 634 pages....😳. Lol.
My group is definitely interested in the idea of USGT. There are 10 in the group. We don't compete, we run for fun. No transponders or lap timers. Grass Roots parking lot racing. It's a competition of who can stay out front the longest.
We've been running 13.5 T/C in a large "L" we set up in a parking lot. Since then we've added a stock 4tec class, and they have all decided to go with a scale type car. I suggested USGT as a guideline for it. They are on board with this. So I've come here, read the entire thread, and let them know USGT rules. They love it. Race liveries and all. They've all picked out their bodies and are starting their builds. I've stressed difference in this area.. in our 4tec class, 6 people run the PF 71 Camaro since it's easy to get. Rather not have that happen with our USGT cars.
With that being said, I've begun to piece together my car. I've picked up a Kyosho TF7 super cheap, going with Tekin ESC/Motor. What I'm having trouble with is the gear ratio, I didn't realize these cars use 64p gears. Where do i go with gearing? I've never used 64 pitch gears before.. kind of lost, lol.
The track quite large, it's in a parking garage local to us. I have YouTube videos of some of our runs, can share a link if any are interested.
thanks in advance for any advice.
If you all plan to run USGT class cars and will use the USGT rules as a guideline then I assume you'll all run 21.5T brushless motors with 'blinky' speed controls (No software boost or turbo), the Gravity RC rubber tires/rims and a proper sport car body and minimum weights. All pretty equal there unless someone just has to spend $200 on a super duper 21.5T motor. Let's not go there.
I run USGT as well as VTA in local club events indoors on carpet and I use an FDR of 3.80 as my base. To calculate FDR, you need to know the internal ratio of your particular sedan. I run an old TC3 sedan in USGT and it has an internal ratio of 2.5 and I run 73T spur with a 48T pinion which gives me an FDR of 3.802. The math is Spur / Pinion x Ratio. In the VTA class I run an old Tamiya TA-05 that has a ratio of 2.0555 and I use 88T spur and a 48T pinion for an FDR of 3.768.
I run indoors on a carpet track and 64P gears as there is little worry about pebbles or other dirt getting into the gears causing issues. I also used 64P outdoors on asphalt when we had a place to race as our track was always swept clean and sprayed with sugar water to help with traction. With the finer 64P, I am able to make smaller adjustments in my FDR when necessary.
Hope this helps
#9514
"The pitch of gears used is a personal choice and what really matters is the Final Drive Ratio (FDR). There are many gear pitches out there from the very old school 32 to 48, 64 and then there are the odd Tamiya metric 48 and 64 pitch gears. I even recall a hybrid pitch in between 48 and 64 that I believe was from Losi. No matter, what you need to focus on is FDR."
Not quite. Yes, 32, 48, 64 and even 84 pitch are "common" imperial pitches. Metric pitches are described as "module". Tamiya (and some other asian brands) use .4, .6, and .8 mod gears. They are not "metric 32" pitch. Amusingly, mod .6 and 48 pitch are pretty darn close, close enough to work for a while, but wear goes through the roof.
Bigger teeth are harder to damage. Bigger teeth have greater difference in shape of tooth, and have more friction. Smaller teeth have less friction, but are harder to setup right. Higher numerical pitch gears also give you a wider selection of available gear ratios. Since the OP is asking, go with 48 pitch.
#9515
Thank you both. I really appreciate the info.
As far as what motors will be run, these guys won't do the whole motor of the month thing. Tekin and HobbyWing will be the motors/esc of choice.
I made it very clear to them the body needs to resemble a production based racecar. No goofy tribal paint schemes.
Track we will most likely use is at Trains and Lanes in PA as it's the closest outdoor on-road course I currently know of. Looks to be kept clean. Since it's not out of the realm to use 48 pitch gearing, I'll go with that since I have a ton of spurs laying around from when I used to have HPI Sprint 2s. They know about Gravity tires, and spoke wheels. They love stuff like this. We follow a similar setup for our parking lot 13.5 cars. No T/C blobs, slicks, or crazy ESC timing. We all love door to door racing.
Only info I find on the TF7 is from Kyosho, says internal ratio is 1.9. I'm not entirely sure how large the Trains and Lanes track is, so I'll have to wait until spring when we go to find out.
#9517
#9519
#9520
My tires just came in. Those things tend to be difficult to get don't they, lol. Just picked out a body, Audi R8 LMS from either Charisma, or Tamiya. Not sure which one yet. Anyone used either have any input?
#9521
Here is the rules list for USVTA, USGT, and F1. Might want to check with your local track to see how closely they stick to them. There is a USGT body list. I don't recall any Carisma bodies on it, but haven't looked recently.
U.S. Vintage Trans-Am R/C Racing Series
#9522
Not sure I'd actually compete. It's just a group of us who plan on doing USGT style cars and going by ourselves. But I will definitely look at the list to see what on it, might change my mind, lol. As I read previous posts, it was always stated any body 190/200mm body. I figured, it's a model of an actual race car so it would fit in.
#9523
The Build RC has the Audi R8 body and they are on the list. I've just order one for myself.
The Build RC 1/10 AUDI R8 PC Transparent 195mm RC Car Body - Option parts & accessories - Cars The Build RC
6563Likes
