USGT
A new M4 body would be awesome.
Side note can someone point me to where some info is on the USGT tires. I ran my car Saturday and found basically when I sauced my tires the car was very balanced and easy to drive to when I tried less “saucing” a car that was very loose and unstable. I don’t think I’ve ever driven a tire where the balance change was so dramatic before.
I have not ran USGT as yet. Just building a car for it now.
I have a question. Do any drivers suffer from traction roll with these USGT tires we are required to use?
Just wondered what amount of grip to expect.
Regards
BM
Regards
BM
On black carpet you will want to glue the sidewalls. Grip is good on black carpet.
they started out with the tt02 bone stock, then we could put the rubber tires on and a bearing kit. Haven't reached the class yet oh, now I'm reading how the real usgt guys do it. Is there anywhere in Michigan that runs this class? Thanks guys and gals! Mess
Traction roll is possible depending on surface, tire prep etc.. Very complicated question to answer
I glued my fronts all the way up the sidewall to the crest. On black carpet it only rolled 1-2 times and only if I heaved it into a hairpin with too much energy and steering input.
6563Likes
