Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 01-12-2022 | 11:57 AM
  #3046
Originally Posted by bentouttashape
Metric hex replacement options for MB3/4 step screws?
Tamiya P/N 54550 and 54409
JJ100179 is offline
Old 01-12-2022 | 12:50 PM
  #3047
Raman's Avatar
Originally Posted by Dark77Hawk
What the best indoor carpet tyres to use for good grip and balance and we’re not allowed to use additive?
The question is why the don’t allow grip sauce? They should mandate a sauce like SXT and have everyone use that
Raman is offline
Old 01-12-2022 | 02:03 PM
  #3048
DirkW's Avatar
Yes, as much as I dislike the messy stuff, I couldn't imagine driving on-road without tire sauce, as pretty much any tire I know more or less requires its use. Luckily, over here the odorless variants are mandatory, so at least no headaches.
SteveM likes this.
DirkW is online now
Old 01-12-2022 | 03:09 PM
  #3049
The just doesn’t allow it in the tamiya stock class
Dark77Hawk is offline
Old 01-13-2022 | 08:15 AM
  #3050
Raman's Avatar
That’s lame.. lol. Sauce will make any tyre work on carpet. Without it, your just inviting people to break their cars.. which is good for the hobby shop at track 🧐
Raman is offline
Old 01-13-2022 | 09:06 AM
  #3051
DirkW's Avatar
Wait, they ban tire sauce but do not set tires to race in a Tamiya stock/spec class?
DirkW is online now
Old 01-13-2022 | 09:43 AM
  #3052
I assume that you are not limited to Tamiya brand tires alone, and if that is the case then you might consider a set of Sorex 22R or maybe 24R soft slicks. I have used Sorex brand rubber tires for years and they have been the best slick tire brand for our carpet racing. We normally use the 28R pre-glued sets and we race on older grey carpet. If you race on the newer black carpet that has more grip, you might need to try 32R or even 36R harder compounds.
If you must use treaded tires, try the HPI X-pattern belted tires. These are 26mm wide and will fit the stock Tamiya rims perfectly. I also like the Gravity RC spec USGT tires that come either pre-glued or separately as rubber tires only. These are 24mm wide, and if you buy just the rubber tires be sure to also purchase the proper width rims.
simple likes this.
SteveM is offline
Old 01-13-2022 | 06:20 PM
  #3053
USGT tires are 24 wide but easily fit on 26mm wide as well. In fact they work better on the 26mm wide wheels because the tires are NOT belted and balloon over time. The 26 mm wide wheels reduce the balloon effect quite a bit. Can't beat the price either, USGT tires are cheap and perform well, long life too.
Raman likes this.
dman18t is offline
Old 01-16-2022 | 01:12 PM
  #3054
Raman's Avatar
Did they ever offer a hop up alternative to the 3x32 MB2 screw, that secures the rear upright, upper and lower?
Raman is offline
Old 01-17-2022 | 05:36 AM
  #3055
Tamiya 54395 is what you can use
hobbs is offline
Old 01-17-2022 | 09:36 AM
  #3056
Thanks!
bentouttashape is offline
Old 01-17-2022 | 12:31 PM
  #3057
Raman's Avatar
Of course they’re sold out everywhere. Darn this pandemic
Raman is offline
Old 01-17-2022 | 03:57 PM
  #3058
f1larry's Avatar
https://www.ebay.com/itm/Tamiya-3x22...-127632-2357-0
ebay
f1larry is offline
Old 01-19-2022 | 09:52 PM
  #3059
Raman's Avatar
One of the things I typically love about Tamiya, is that majority of parts can be use across their kits.. eg from TT02 to TRF420. Tonight however I hit a major hick up.
I purchased 39mm DCJ joints for my TT02 RR. The dcj package comes with a 5x10x3 bearing. Well it turns out, it’s not enough, the cross pin won’t go in. I tried it on 4 hubs. Nope!
You need a 5x10x2.5 bearing.. good luck finding one! 🤦🏻
jgil089 likes this.
Raman is offline
Old 01-19-2022 | 10:43 PM
  #3060
OVA's Avatar
OVA
that suck
OVA is offline
