Tekno RC ET410 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree469Likes
Last edit by:
Print Wikipost
Old 12-07-2021 | 10:56 PM
  #1216
Question on servo horns. I know they sell an aluminum one.. Kid has a generic protek one that came with his 160tbl servo and it seems to be fine.
Any reason to change it out for the Tekno one dimensionally?
Silverbullet555 is offline
Old 12-08-2021 | 06:56 AM
  #1217
The Tekno servo horn has offset to clear the front bulkhead brace. You could probably use spacers to achieve the same thing but the Tekno part is nice.
76jimmy is offline
Old 12-08-2021 | 07:52 AM
  #1218
I figured as much. I was surprised that my kid's worked with the generic servo horn. Figured I would check to see before I spent more money.
Old 12-08-2021 | 08:14 AM
  #1219
Next question. Prostar one piece top plate for an ET being run on carpet with foams? It'd be more rigid, Not sure if good or bad.
Old 12-08-2021 | 10:06 AM
  #1220
Carpet with foam tires is probably like driving on Velcro lol. I'd try it with the brace. No experience with those conditions just my 2¢
Silverbullet555 likes this.
76jimmy is offline
Old 12-11-2021 | 12:45 AM
  #1221
Kajman's Avatar
Originally Posted by Tim W.
Same with our track! We run ET410s with Gone Bananas foam tires and everyone has a smile and a laugh during the race that's why I got one!
Where did you get foam tires and what model?
Kajman is offline
Old 12-11-2021 | 07:02 AM
  #1222
lowspark's Avatar
A plastic servo horn will strip out. That is why people switch to alum servo horns.
lowspark is offline
Old 12-11-2021 | 07:35 AM
  #1223
His is aluminum. Its working for him so we will let it be.
platgof likes this.
Old 12-11-2021 | 07:36 AM
  #1224
Facebook gone bananas racing skins. Send him an im telling him what you need.
Old 12-19-2021 | 08:49 PM
  #1225
Going to try some upper chassis braces next carpet race
Cromulent is offline
Old 12-19-2021 | 09:31 PM
  #1226
Interesting. An aftermarket part or custom?
Old 12-19-2021 | 09:50 PM
  #1227
Just something I pieced together from a Traxxas 2444 turnbuckle set (67mm center to center), with a more standard ball insert on one end (insert from a 1942 kit). 3x32mm screw at the rear, 3x18mm screws at the front, and a few washers and nylock nut.
Now that I’ve done it that way, I’d recommend just getting the Traxxas 1942 ball end kit and whatever 3mm turnbuckles to get you to ~67mm CtC length (perhaps ~50mm TBs).
Old 12-20-2021 | 04:07 AM
  #1228
Some guys were talking about running thier et's on the carpet. I pulled mine out to take a look. Needs total rebuild after using it on an eighth scale track all summer. Have a small list of parts to get it ready. Figured I'd use the same tires I use for my t6.2 swagger fronts and pin down rears.
76jimmy is offline
Old 12-20-2021 | 06:27 AM
  #1229
There's a pretty healthy class here on carpet. Most run foams for longevity and to reduce some of the traction rolling issues.
Old 12-20-2021 | 08:02 AM
  #1230
Kajman's Avatar
Do they trim those foams during day? Where to buy such size?
Kajman is offline
