Like Tree3Likes
  • 2 Post By DirkW
  • 1 Post By DirkW
Hobbywing 1S ESC
Old 10-21-2021 | 11:50 AM
Default Hobbywing 1S ESC
I bought a Hobbywing XERUN XR10 pro 1S ESC. 2 issues:
1) It won't let me calibrate it to the transmitter, however, the esc functions with throttle and brake.
2) When I want to shut the ESC off, I have to turn the transmitter off first, then the esc light turns solid red and I can shut it off. It is in the green blinky mode. The transmitter is a Futaba 7PXR.
Thoughts?
hunterdawg is offline
Old 10-21-2021 | 12:09 PM
DirkW's Avatar
Some ESCs need the throttle to be set on reverse on the radio (usually on Futaba). I'd try that first.
Andy Koback and glennhl like this.
DirkW is offline
Old 10-21-2021 | 12:29 PM
Thoughts?
Should always turn the ESC off first before the radio.
Andy Koback is offline
Old 10-21-2021 | 12:33 PM
I did have to reverse the throttle. I can't turn the esc off until the radio is off. Wonder if I should turn off blinky mode?
Old 10-21-2021 | 12:50 PM
DirkW's Avatar
I don't think adding boost and/or turbo would cure your problem, but you can of course try. Also you might try flashing the firmware...
gigaplex likes this.
DirkW is offline
