-   -   Hobbywing 1S ESC (https://www.rctech.net/forum/radio-electronics/1091133-hobbywing-1s-esc.html)
hunterdawg 10-21-2021 11:50 AM
Hobbywing 1S ESC
I bought a Hobbywing XERUN XR10 pro 1S ESC. 2 issues:
1) It won't let me calibrate it to the transmitter, however, the esc functions with throttle and brake.
2) When I want to shut the ESC off, I have to turn the transmitter off first, then the esc light turns solid red and I can shut it off. It is in the green blinky mode. The transmitter is a Futaba 7PXR.
Thoughts?
DirkW 10-21-2021 12:09 PM
Some ESCs need the throttle to be set on reverse on the radio (usually on Futaba). I'd try that first.
Andy Koback 10-21-2021 12:29 PM
Thoughts?
Should always turn the ESC off first before the radio.
hunterdawg 10-21-2021 12:33 PM
I did have to reverse the throttle. I can't turn the esc off until the radio is off. Wonder if I should turn off blinky mode?
DirkW 10-21-2021 12:50 PM
I don't think adding boost and/or turbo would cure your problem, but you can of course try. Also you might try flashing the firmware...
