Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 09-02-2021 | 10:23 AM
  #2836
Raman's Avatar
Originally Posted by Monsta
Hi Raman,
My CVAs finally showed up, i was in the process of installing them when i noticed (and i dont know how i never noticed before) that the rear hubs have a travel limiter. I realised the rear has zero droop.
Is this limiter normally removed?
Post a picture of these limiters
Raman is offline
Old 09-07-2021 | 07:10 PM
  #2837
Monsta's Avatar
sorry for the delay.
These are the limiters, depending on if you have it set high or low. They contact the lower arm at droop/when load is off the wheels.
In my case the were in contact at normal ride height.
I ended up cutting the bottom ones off. now with CVAs and 1mm front and 2mm rear droop it feels better on the driveway. I have to wait until our current lockdown ends to see if its better at the track.
Monsta is offline
Old 09-10-2021 | 04:09 PM
  #2838
Default Spur Mounting
New guy. Learned a lot here so thanks to all.
Question: I use 48P Kimbrough Spurs in my TT-02. In order to mount them to the alloy hub from the HS Gear Kit, since only two tapped holes line up with the Kimbrough Pattern I've had to transfer/locate, drill, and tap two additional holes in the Hub. This works fine but is a huge pain in the neck. Do you Kimbrough folks modify your hub or just fasten the spur with two screws only? I feel like I must be missing something!
Electric Ned is offline
Old 09-11-2021 | 06:54 PM
  #2839
Raman's Avatar
2 mount holes is more than enough.
Raman is offline
Old 09-12-2021 | 04:38 PM
  #2840
I'm a novice when it comes to road cars so I'll certainly take your advice to heart.
Is that really what all the Robinson guys do? Just mount with 2 screws? I'd think 4 would better distribute the load and be less prone to distorting the gear.
Waddya think?
Old 09-12-2021 | 07:05 PM
  #2841
Raman's Avatar
Waddya think?
its very common. Not just with Robinson racing, but most non Tamiya gears. I use Zenon or Panaracer on my TA05, TA08 all which. I use for racing, all spurs are mounted with 2 screws.
2 is more than enough, have no worries 😉
Raman is offline
Old 09-13-2021 | 02:12 AM
  #2842
DirkW's Avatar
I disagree. Just a bit... and and not seriously. Let's just say, two screws are enough. Period. See, in my twisted little brain, two being "more than enough" could be interpreted as even one is enough (since two are more than enough.. and two is more than one... and although I have never tried it, I'd say one is not enough.
Sorry, just had to tickle my funny bone there, Raman. But on the issue here: fixing a spur with two screws is absolutely and definitely enough on the TT-02.
TurboThirdGen likes this.
DirkW is offline
Old 09-13-2021 | 04:09 PM
  #2843
Monsta's Avatar
Hi Raman,
These are the limiters on mine. are they not on all variants of the TT02?
Monsta is offline
Old 09-13-2021 | 09:14 PM
  #2844
First, I've been on RC Tech for over 2.5 years, and originally got involved in RC over 35 years ago. Second...and more importantly (not to mention, more appropriate to this thread)...I just acquired two TT-02 kits...one for me, and one for my step-dad. While my Step-dad does have two other RCs (2WD Traxxas Slash, ProBoat Recoil 17), he has never built a kit. The TT-02 will be his first kit. However, instead of just getting a kit for him to build, I thought it would be fun for us to build our own, separate, kits side-by-side. Although, in typical 'Black Cat' fashion, both will have a few upgraded parts right off the bat (oil-filled shocks, bearings, and some other goodies). Mine, however, will be upgraded considerably more than his, as I have secondary plans for mine - racing. I've already acquired most of what I'll need (including the High-Speed Gear Set), while other parts are either on their way, or will be ordered soon. HOwever, there are two things I could GREATLY use some assistance on.
First, starting with the aforementioned High-Speed Gear Set, I know there are other-branded spur gears that will fit the spur adapter...but, I do not know which. I know the stock spur is .6Mod, but I'd prefer to go with 48P. What quality...and, I do want to emphasize 'quality'...48P spur gears will fit the High-Speed Spur adapter? Associated? Kimbrough? Others? Second has to do with an 'alternate' parts upgrade route I am considering, namely the Yeah Racing TATT-S04 Competition Touring Car Upgrade Kit. Is this a good/smart idea? Or, should it be avoided? I know that most parts from Yeah Racing are quite good...but, I also know some of their stuff is "just ok", and some should be left alone. I'm not concerned with the price...just the quality, and length of usability. An input would be appreciated.
Panther6834 is offline
Old 09-14-2021 | 07:33 AM
  #2845
Raman's Avatar
Hi Raman,
No, not on the type S. I think those limit the movement to stop the dog bones from popping out. They’re not for droop. For droop you would place inserts inside the shocks, eg 1mm spacers, 2 mm spacers. A royal PITA but that’s the TT02 suspension lol.
Raman is offline
Old 09-14-2021 | 06:08 PM
  #2846
Monsta's Avatar
Yeah ok. They definitely only limit the down travel so maybe a cheap droop fix for the chassis with friction shocks.
I just bought some spare sprues that are from the TT02D, gray parts, and they're the same.
They dont have them on the front hubs.
Monsta is offline
Old 09-15-2021 | 05:11 AM
  #2847
I'm glad that someone asks about those downstops. I have already built a couple of TT-02 and also got puzzled about the stops. If you built the Kit according to manual, the chassis is " wrong way wedge" - >way more ground clearance in front than in the rear, which is really odd imo. You cannot address with the stock springs as they are way too hard.
It gets better with the hop-up aluminum rear hubs, they have no downstops and because of that the ground clearance levels out between front and rear.
​​​Weird....
JJ100179 is offline
Old 09-17-2021 | 03:04 PM
  #2848
RabidDog's Avatar
Hi,so i just ordered a tt-02 kit for drifting.....yes i know tt02d
all on backorder ,,,so what is the difference between the 2?
what would it take in parts for a tt02=tt02d....
ty
RabidDog is offline
Old 09-17-2021 | 03:12 PM
  #2849
ty
Did you bother checking eBay first? There are quite a few TT-02D kits (without outrageous price markups) available.
Old 09-17-2021 | 03:55 PM
  #2850
DirkW's Avatar
ty
Differences are that the TT-02D has:
  • full set of ball bearings
  • oil filled shocks (50746 x 2)
  • Tamiya Sport Tuned motor (53068.1)
  • Motor Heat Sink (54571)
  • Wheels (9335534)
  • Drift tires (54020 x 2)
that should be about all.
DirkW is offline
