Like Tree256Likes
Tamiya TRF419
Old 08-11-2021 | 09:03 PM
  #4591
I’ve never gotten the 418/419 arms to work well. I haven’t had a chance to try the 420 suspension yet. That might change things. But I really like the 417 arms still
Juan Aveytia is offline
Old 08-12-2021 | 11:23 AM
  #4592
I love my TRF-420. Love Tamiya cars
Timken500 is offline
Old 08-12-2021 | 11:29 AM
  #4593
Raman's Avatar
Your primarily want the 53926 hard versions right? I’ll check when I’m home
Raman is offline
Old 08-12-2021 | 08:44 PM
  #4594
Raman's Avatar
How much? And how many sets do you have?
I have 2 NIB carbon reinforced and 2 standard.. see PM.
Raman is offline
Old 08-13-2021 | 03:15 AM
  #4595
badboy's Avatar
Thank you!
badboy is offline
Old 09-10-2021 | 11:40 PM
  #4596
Default Sorry to ask a painful question
I'm looking for a basic black carpet setup for 419x with suspension upgrade. Nothing else has been upgraded beside progressive 2.5-2.8 front and 2.6 rear. Springs any info would be great.
hotrod306 is offline
Old 09-11-2021 | 06:18 AM
  #4597
You better find an aluminum chassis if you haven’t yet. I’d try to copy an Xray T4 2017-2019 set up. Should get you in the ball park
Old 09-24-2021 | 02:34 PM
  #4598
Hey guys
Does anybody know of an alternative centre pulley that will fit my 419xr?
Its basically impossible to get the 2 halves in the UK.
Will the 420 part fit?
13454936
And
13454938
hipwell is offline
Old 09-24-2021 | 02:52 PM
  #4599
Raman's Avatar
Originally Posted by hipwell
Hey guys
13454936
And
13454938
Prior to installing the 420 pulleys on my TA08, I test fitted them to 419. It can be made to work but will require different size bearings and spacers as it’s more compact than the 419.
I didn’t have the right size bearings so I didn’t go further.
Raman is offline
Old 09-24-2021 | 03:43 PM
  #4600
Ah that's a shame.
Did you test on an original 419 or an XR?
The XR has got a different centre shaft and bearings but uses the same pulleys.
hipwell is offline
Old 09-24-2021 | 03:46 PM
  #4601
Raman's Avatar
Apologies, I have the 419XR as well. The test was done on XR
Raman is offline
Old 09-25-2021 | 02:09 AM
  #4602
Electr0n's Avatar
Hey guys
13454936
And
13454938
Will try it this afternoon and let you know
Just fitted the TA-08 Pro parts on my 419XR.
With the correct bearings and some shimming it will fit perfectly
Electr0n is offline
Old 09-25-2021 | 09:09 AM
  #4603
Brilliant, can you let me know the bearings you required? If I can fit the 08 pro parts that will be fine, anything will be better than my chewed up 419 pulleys!
hipwell is offline
Old 09-25-2021 | 10:25 AM
  #4604
Electr0n's Avatar
With the bearings provided in the TRF 420 kit.
info and assembly see, https://www.tamiya.com/english/rc/rcmanual/42345.pdf
Electr0n is offline
Old 09-25-2021 | 02:14 PM
  #4605
Brill.
So I need the bearings from a 420 centre pulley, and the pulleys from a ta08 pro?
hipwell is offline
