Like Tree195Likes
Novarossi engines thread
Old 04-12-2021 | 10:16 PM
  #6046
Originally Posted by sinisterRC
You can see the weight all the way to the right was out, the middle weight also was loose.
I see.. That is very odd..
None of my engines got that problem..
My Mephisto has only 1 tungsten weight, why your has 3 of them? Oh, I see now, mines are off road Mephisto, yours is on road..
GeorgeCk is offline
Old 04-14-2021 | 05:17 AM
  #6047
Pooh2's Avatar
LOCTITE IT BACK IN AND IT WILL BE FINE.
Pooh2 is offline
Old 05-29-2021 | 09:00 PM
  #6048
illmatic94's Avatar
Default Glow plugs
With novarossi going out of business and all my engines being ... novarossi. I will be running os plugs now. Is it safe to say that the hot plug P3=ct5 and coldest plug rp8 = ct8?
illmatic94 is offline
Old 05-30-2021 | 03:25 AM
  #6049
Losi215's Avatar
Hey guys! Not trying to spam the forum as I posted a question in the off-road nova forum, but received no response. Doesn’t anyone have information on a Max power 07999 rod and can it be used in novarossi engines? Looking for a replacement for an R7 rod, some European websites list it as an R7 alternative or for use in novarossi engines as well. My novarossi p5xlt shares the exact same bore and stroke as all the high end Max power engines, which as far as I know are all novarossi based. Does anyone have concrete answers on this? Thank you I’m advance, love this forum.
Losi215 is offline
Old 05-30-2021 | 04:54 AM
  #6050
rp7 = ct8 = from 10 to 35-40 Celsius degrees.
rp6 = ct7 = if colder
rp8 = ct9 = if very hot
gilesdhay is offline
Old 06-01-2021 | 03:02 PM
  #6051
Glutton's Avatar
Thanks, I had been wondering about this. How about using a Picco P7TC on a Nova engine? P7TC ~ CT8?
Glutton is offline
Old 06-05-2021 | 06:44 PM
  #6052
Hey there,
I am trying to fix up my novarossi keep-on .12 motor.
It needs a new conrod and bearings.
What kind of bearings and conrod does it use? the novarossi website is down so I never got a chance to look. And where could I buy bearings from?
kartarish is offline
Old 06-05-2021 | 10:56 PM
  #6053
Glutton's Avatar
Originally Posted by kartarish
Hey there,
https://images.amain.com/images/reso...%20Diagram.pdf
Here is a link to the exploded view of the motor. Should be easy enough to look up the parts if anyone has them in stock.
Glutton is offline
Old 06-07-2021 | 02:26 PM
  #6054
Default Novarossi Top Elite 21 On Road 9 Port
Hello!
I am getting back into nitro this summer, and will be running my Inferno GT2 cars for some parking lot racing.
Absolutehobbyz has a great deal on the Novarossi Top Elite .21 9 port on-road motors ($240/unit), and I was planning on picking one up to try this season.
  • Does anyone have experience with this motor?
  • If so, what off-road pipe combo will work best?
I've got an Ofna 086 pipe that I run on all motors, will this suffice?.. or am I in danger of damaging the motor with this pipe combo?
Any advice is helpful.
Thank you!
Mr. Nice Guy is offline
Old 06-07-2021 | 10:11 PM
  #6055
Hey there,
I am trying to clean my motor, ive gotten as much of the baked on foam off from the tires using a brush and 99% iso alcohol.
I saw a method for pipes to put them in a crocpot with antifreeze and the results were spotless (youtube video).
Would this be worth trying? or is there any other methods too (for heatsink and engine block)
Old 06-08-2021 | 04:03 AM
  #6056
1/8 IC Fan's Avatar
Crockpot and antifreeze is by far the best method I have used. Takes some time but works great.
andreas78 likes this.
1/8 IC Fan is offline
Old 06-09-2021 | 08:18 AM
  #6057
What's the procedure for it? and would antifreeze in a pot work? if i keep it on low heat
Old 06-09-2021 | 04:37 PM
  #6058
Bundy_Bear's Avatar
Don't do it in the house, the fumes from it are toxic. Advantage of a slow cooker/crockpot as heating isn't always on. I use a slow cooker for mine on a low heat for 24 hours. Take out about half way through and give a brush using an old toothbrush and put back in.
Bundy_Bear is offline
Old 06-09-2021 | 05:06 PM
  #6059
do I use 50/50 coolant or antifreeze concentrate?
Old 06-09-2021 | 06:44 PM
  #6060
Bundy_Bear's Avatar
Concentrate
