Roche Rapide P12 Evo 1/12th Competition Kit >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree91Likes
Last edit by:
Print Wikipost
Old 04-19-2020 | 05:43 AM
  #181
Originally Posted by tommysnow7
Anyone know where I can find some more front axles (spring steel) part number 330016? Seems that everyone is sold out right now.
Try www.speedyrc.com.au located in AUS if you get stuck.
Searlands is offline
Old 04-19-2020 | 06:02 AM
  #182
Running the Xenon balls and cups.
So much “free-er” than the kit ones. Zero play too.
Old 04-19-2020 | 07:05 AM
  #183
Thanks! They only have one pair in stock, the shipping to the US wouldn’t be worth it. Appreciate it though!
Searlands likes this.
tommysnow7 is online now
Old 04-19-2020 | 10:14 AM
  #184
hanulec's Avatar
fyi- The AE r6 front axles also fit
hanulec is offline
Old 04-19-2020 | 10:28 AM
  #185
good to know! Thanks!
Old 04-19-2020 | 12:59 PM
  #186
hanulec's Avatar
Also the shorter axles are really our popular item--
Front Axle (Spring Steel) -0.5mm
hanulec is offline
Old 05-12-2020 | 06:12 AM
  #187
The axles above are a lot better than the kit ones. No need to shim out the play. 😊
Old 09-07-2020 | 11:15 AM
  #188
Romac's Avatar
Looking at replacing my P12 17 is the EVO still the latest car?
Is Roche working on a new kit?
Thanks,
Rob
Romac is offline
Old 09-07-2020 | 12:46 PM
  #189
hanulec's Avatar
Thanks,
Rob
The Evo is the current car
No solid eta on a new model
hanulec is offline
Old 10-05-2020 | 01:05 PM
  #190
okx
Can someone explain why almost always spool goes in combination with wider front?
And does it work on ETS carpet with low-medium grip or better to keep standard front width?
okx is offline
Old 10-05-2020 | 01:29 PM
  #191
hanulec's Avatar
No true
Front width is tire dependant. If you running a hard tire, like the "spec" lilacs in the usa, then a narrow front end is best to make the car turn
I've never run ETS rug, but at Worlds the UK team was saying everyone is running spool now no matter the carpet type. Grip eventually rises and spool wins over diff
RacinJ likes this.
hanulec is offline
Old 10-07-2020 | 04:37 PM
  #192
Nuno Gancho's Avatar
Looking to have more off and on power steering what will. E difference if use long or short front bulkhead and same on long or short rear wheel base.
the rear axel height adjuster for final car height will it be any difference if using high or low position
thanks
Nuno Gancho is offline
Old 12-01-2020 | 11:41 AM
  #193
ospower's Avatar
will this servo fit the p12 evo?
ospower is offline
Old 12-01-2020 | 03:18 PM
  #194
hanulec's Avatar
Adding this part allows servos bigger than 33mm wide to work----
Rapide P12 EVO Aluminum Servo Mount (Large Servo Mount)
gwc likes this.
hanulec is offline
Old 12-01-2020 | 09:40 PM
  #195
ospower's Avatar
thanks!
ospower is offline
