Like Tree383Likes
My new Touring.
Old 04-20-2020, 07:51 AM
  #31
theproffesor's Avatar
Trader Rating: 66 (100%+)
I’m not sure you caught what I was saying. I was referring to the bell crank arm as marked the picture. Why can it not be attached in this location?
or... rotate the servo 90 degrees with the servo saver to the outside, pushing the servo as close as you can to the center, and use a “L” arm for the bell crank.
theproffesor is offline
Old 04-20-2020, 09:22 AM
  #32
Eotz's Avatar
Placing the link to the place you marked with the red point won't work. When you turn the car to the right, will be fine, but turning to the left, the bridge will hit the ball stud and block the steering.
Eotz is offline
Old 04-20-2020, 10:50 AM
  #33
In that exact location yes, but the center of the arm is covered by the steering linkage in the pic. If the ball stud were centered on the bell crank arm, I’m sure you could still get more than adequate clearance. And if was raised.
The point I was getting at, is why is the default, the center of the bridge for the ballstud position? has any attempt, by anyone been made to alter this once servos and materials became much stronger than 20 years ago?
Old 04-20-2020, 08:21 PM
  #34
Not to be a pain but the biggest problem I had with linear steer was gaps and wear in the track. 3 bearings with one on an eccentric allowed compensation for wear. Its very sensitive to too little gap as well. You would feel the bearings slightly bind if you tighten the eccentric too much. either way you know what you are doing but I’d hate to see you have to make revisions later because you missed something that seems trivial.
Bry195 is offline
Old 04-22-2020, 04:39 AM
  #35
Eotz's Avatar
At the moment nothing is decided. My plan is to made one prototype of each kind of direction and try then.
Eotz is offline
Old 04-24-2020, 07:33 AM
  #36
Eotz's Avatar
The motor mounts are not 100% finish, but almost.
Eotz is offline
Old 04-24-2020, 08:16 AM
  #37
wtcc's Avatar
So cool
wtcc is offline
Old 04-25-2020, 09:54 PM
  #38
Eotz's Avatar
Finished
wtcc, walrusjon and Bry195 like this.
Eotz is offline
Old 04-25-2020, 11:29 PM
  #39
walrusjon's Avatar
I like you bulkhead design. To make the motor mount more slim
walrusjon is offline
Old 04-27-2020, 08:58 AM
  #40
Cool information
RayCharle is offline
Old 05-04-2020, 11:11 AM
  #41
Eotz's Avatar
Talking
After flying 2000km from Mecanizados Leniz, at the Basque Country, the parts arrived today. Machined in Aluminum 7075. All fitted as expected. Great job.
The project is going slowly (Comparing to wtcc ones) but without pause.
Eotz is offline
Old 10-18-2020, 01:37 PM
  #42
Woooow
OliverWilkins is offline
Old 10-18-2020, 01:38 PM
  #43
Yo,I would love to see this car in move
Old 10-21-2020, 03:28 PM
  #44
YoDog's Avatar
Trader Rating: 28 (100%+)
Default My take
Here is the steering I opted to use on my shaft drive project. It provides full motion without interference. It also incorporates a servo saver in the center linkage post. I’m not sure if it was made by Associated or not but you could easily model it up for your project. I did this one prototype plus 6 more conversions
several years ago and still get compliments on its performance.
Flipside6900 likes this.
YoDog is offline
Old 10-23-2020, 08:04 AM
  #45
Eotz's Avatar
Hi.
This steering looks great. Could you made a 3D model yourself?
Last months I have all in pause, I have no free time and the guy who print the parts for me became father and now, he also have no more time
Eotz is offline
