My new Touring.
My new Touring.
Hi all.
As wtcc asked me, I create a thread for the Touring I'm designing. The first prototype is ongoing, but not jet finish. I have too little free time to invest at the car. I design it to run at the GT category with 21,5 or 17.5T motor at my local track in Braunschweig (Germany). The idea is to create a competitive, but simple car. Nothing revolutinary. Shaft transmission, low profile dampers and 100% simetric lower chassis.
Just a couple of renders of the CAD model. I hope you like then.
Best regards.
Best regards.
Awesome! Finally
Such quality design needs a place where everything is documented.
I am looking forward to the upcoming developments
I use a mix of TT-01 and TT-02 transmission parts. For the first car I'm using a 3Racing ball differential and solid axe. As you can see, all the electronic is placed over a floating plate. Here a picture of the first prototype. As I say is half done. The bulkheads are not the final ones, they are just in PLA printed to validate the design. The finals will come in Nylon-X. The front suspension harm is also not the final one but is printed with the right material. Rear suspension harms will be also printed with Nylon-X. The steering and motor mount is also ongoing. I'm looking what is better (And cheaper), print the motor mount in metal or machined.
Looks very nice and neat! Hope to see more of this soon.
It looks really nice. I like shaft drove tourers.
I just have to ask, what's reason for use of TT-01/2 gears? They're quite big and rough, while TB-series gearing is more compact with variety of differential mechanism and gear ratios.
For the motor mount you can use an already existing design if you want to save money:
EXO-SIX.2 MOTOR MOUNT SET, replacement - Exotek Racing
I bought one just in case... you know.
Because I have a TT-01 and my son a TT-02. So I already have some parts. I search for TB differentials and I found only front solid axes. But if you can send me a link I will appreciate it.
On the Exotek motor mount you can remove the support ring. It it attached with a screw. So you end up with the lower motor mount only. The size might help with motor heat ( maybe that is why they made it that big
That distance is 17mm on the Exotek mount.
At my part is only 13mm.
https://www.t2shop.de/epages/6174632...2&Locale=en_GB
Gear differential is only available in parts, part numbers are listed in manuals - TB04, 05 and Evo 6 & 7 use identical or very similar units with 2.5 gear ratio, so spare or optional parts can be used from any of these models. List is pretty long, so I'm not sure if I'd be able to list all parts available.
Some parts from TB03 and TB Evo 5 also compatible - those models used ball diffs and 2.43 internal ratio. TRF502 gears, which use 12 3/32 balls instead of 9 3mm, can be used as optional part for TB03 diff. But 03 and Evo5 are more than 10 years old, so their parts are becoming harder to source.
This is only complete set I found
Some parts from TB03 and TB Evo 5 also compatible - those models used ball diffs and 2.43 internal ratio. TRF502 gears, which use 12 3/32 balls instead of 9 3mm, can be used as optional part for TB03 diff. But mentioned models are more than 10 years old, so their parts are becoming harder to source.
Repeated
