Like Tree2Likes
  • 2 Post By billdelong
HV Servo question
Old 02-11-2020 | 10:34 AM
MOTORMAN29's Avatar
Default HV Servo question
I tried searching but can't find the answer I was looking for... probably cause it's a dumb-ass question....(and been out of this for a while...)
Can I use a HV steering servo with a old Tekin RS Pro ESC? or will I need to add a BEC? The servo I'm looking at is a Savox SB-2265MG. Is there a voltage setting I need to set thru Hotwire? I want to use 7.4V, I will also be using a Sanwa RX-482 receiver if that matters.
building an old touring car for club races
Thanks for the help!!!
MOTORMAN29 is offline
Old 02-11-2020 | 10:51 AM
the rc guy's Avatar
yes you will need to set bec thru hotwire.. all else is safe at 7.4v
the rc guy is offline
Old 02-11-2020 | 11:03 AM
MOTORMAN29's Avatar
OK, just looked up the manual and it's only 6v @ 3amp...…( I did mention it's old!) so that tells me I'll need a new ESC... yea! buy more stuff!! :-)
Thanks RC Guy! you driven me to search again!
Old 02-11-2020 | 12:17 PM
The servo will work correctly on the 6V, only a tiny bit slower.
You can hotwire the servo: https://www.rcgroups.com/forums/show...o-from-2S-LiPo
Here the red wire is connected to the balancer plug but you can solder it directly on the battery + wire.
Roelof is offline
Old 02-11-2020 | 02:10 PM
MOTORMAN29's Avatar
Thanks for the option Roelof, but doesn’t that leave the servo from any type of protection?? or do they usually have some type if internal overload? I do have a CC bec i guess i could use from my crawler. I’m getting older and starting to like the plug n play method lately. The only Hotwire i want to use is Tekin’s, lol.
Old 02-11-2020 | 02:33 PM
What kind of a protection do you expect and from what? A BEC is no protection for a servo
Roelof is offline
Old 02-11-2020 | 03:16 PM
MOTORMAN29's Avatar
I guess your right, I always used BEC's to get more current to the servo since the ESC was only allowing a max of 3-4A. Good point, thanks Roelof!. Do you think a 2S HV pack would fry a servo at 8.7V?
Old 02-11-2020 | 11:18 PM
Athough some people think 7.4v is the limit it is not.
The 7.4v notation is because the normal specified voltage of a 2S battery is 7.4v so it will work with 8.4v. 8.7 is just a fraction more.
Roelof is offline
Old 02-12-2020 | 05:46 AM
If your BEC is limited to 6V and you still want to run the servo on 8.4V, then you can pull the HV from the balance wire like this:
How to wire HV Servo from 2S LiPo
MOTORMAN29 and GerryH like this.
billdelong is offline
