-   -   HV Servo question (https://www.rctech.net/forum/radio-electronics/1059883-hv-servo-question.html)
MOTORMAN29 02-11-2020 10:34 AM
HV Servo question
I tried searching but can't find the answer I was looking for... probably cause it's a dumb-ass question....(and been out of this for a while...)
Can I use a HV steering servo with a old Tekin RS Pro ESC? or will I need to add a BEC? The servo I'm looking at is a Savox SB-2265MG. Is there a voltage setting I need to set thru Hotwire? I want to use 7.4V, I will also be using a Sanwa RX-482 receiver if that matters.
building an old touring car for club races
Thanks for the help!!!
the rc guy 02-11-2020 10:51 AM
yes you will need to set bec thru hotwire.. all else is safe at 7.4v
MOTORMAN29 02-11-2020 11:03 AM
OK, just looked up the manual and it's only 6v @ 3amp...…( I did mention it's old!) so that tells me I'll need a new ESC... yea! buy more stuff!! :-)
Thanks RC Guy! you driven me to search again!
Roelof 02-11-2020 12:17 PM
The servo will work correctly on the 6V, only a tiny bit slower.
You can hotwire the servo: https://www.rcgroups.com/forums/show...o-from-2S-LiPo
Here the red wire is connected to the balancer plug but you can solder it directly on the battery + wire.
MOTORMAN29 02-11-2020 02:10 PM
Thanks for the option Roelof, but doesn’t that leave the servo from any type of protection?? or do they usually have some type if internal overload? I do have a CC bec i guess i could use from my crawler. I’m getting older and starting to like the plug n play method lately. The only Hotwire i want to use is Tekin’s, lol.
Roelof 02-11-2020 02:33 PM
What kind of a protection do you expect and from what? A BEC is no protection for a servo
MOTORMAN29 02-11-2020 03:16 PM
I guess your right, I always used BEC's to get more current to the servo since the ESC was only allowing a max of 3-4A. Good point, thanks Roelof!. Do you think a 2S HV pack would fry a servo at 8.7V?
Roelof 02-11-2020 11:18 PM
Athough some people think 7.4v is the limit it is not.
The 7.4v notation is because the normal specified voltage of a 2S battery is 7.4v so it will work with 8.4v. 8.7 is just a fraction more.
billdelong 02-12-2020 05:46 AM
If your BEC is limited to 6V and you still want to run the servo on 8.4V, then you can pull the HV from the balance wire like this:
How to wire HV Servo from 2S LiPo
https://c1.staticflickr.com/9/8797/1...b4f1c60e_c.jpg
