Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 11-26-2019 | 08:49 AM
  #2191
Either there's something wrong with the servo saver, or you're missing bits in the stack up. What you're describing is not normal for that servo saver.
Nerobro is offline
Old 11-26-2019 | 02:43 PM
  #2192
I found mine was clocked by a fair amount, compared to the stock servo saver. If I moved it either direction on the spline, I'd have to max the trim on the radio gear, to get the car to drive straight.
Went back to the stock servo saver and it only needed a small amount of trim. More investigation needed.
Bloke is offline
Old 11-26-2019 | 02:46 PM
  #2193
nikkiesteban's Avatar
Here's the video.
https://www.dropbox.com/s/7xi5ramfxd...63709.mp4?dl=0
nikkiesteban is offline
Old 11-28-2019 | 08:30 AM
  #2194
chucko's Avatar
Originally Posted by nikkiesteban
3 things check the servo . then if that s not the issue put a solid arm on it . the video looks like its skipping a tooth,,, is the right count on it. savox is 25 and sometimes they hit it with a 24 if its not titanium.. I just changed a servo out because it would not center . but it was 12 yrs old. good luck
chucko is offline
Old 11-29-2019 | 03:29 PM
  #2195
servo is not moving in the video. It's the servo saver itself moving left and right and doesn't re-center itself if forced too much. I tried to install the plastic servo saver included in the kit. It's much better than the high torque servo saver in the steering upgrade kit. It re-centers itself. I will try and order a new high torque servo saver. Seems like the one i got has a problem with the metal spring (small and large).
Old 11-29-2019 | 03:31 PM
  #2196
Double post
Old 11-29-2019 | 08:08 PM
  #2197
Try a bit of grease between friction surfaces and don't go gorilla tight on screw. Let thread lock do its job.
GimpyGolden is offline
Old 11-30-2019 | 12:35 PM
  #2198
chucko's Avatar
Yeah I see your pushing on it with your finger. is it turning on the spline and bolt area where it connects to the servo ?. I was thinking it could be a gear in the servo or just an effed up savor.
chucko is offline
Old 12-01-2019 | 06:28 AM
  #2199
The spline is not moving. Maybe a faulty servo saver. Well it's working but not centering very well. Unlike my other tamiya HT servo saver installed in my m05 it centers very well even if you force it.
Old 12-04-2019 | 02:35 PM
  #2200
https://realtinker.blogspot.com/2019/12/the-tamiya-tt02-just-02-not-b-not-r-not.html
So, I built one. I drove it on gravel. I like it.
rippen, chucko and JJ100179 like this.
Nerobro is offline
Old 12-05-2019 | 03:25 PM
  #2201
Raman's Avatar
Soon to be released 47439 1/10 TT-02 Type-SR Chassis Kit? Swap bars please!
rippen and Nerobro like this.
Raman is offline
Old 12-11-2019 | 10:08 AM
  #2202
proliteandsc's Avatar
Hope it's the type s with useful upgrades that will help racers.
rippen likes this.
proliteandsc is offline
Old 12-11-2019 | 10:19 AM
  #2203
Default Need VTA setup for TT-02 s
Looking to use a TT-02 Type-S in VTA. Anyone have a setup I can start with or know where I can find one? I'm racing on a very small asphalt track.
Old 12-11-2019 | 11:24 AM
  #2204
f1larry's Avatar
Yes hopefully this is just a R version of the S and comes with all the aluminum upgrades the regular R or RR come with. If so this will be the Pro Spec setup to have.
f1larry is offline
Old 12-11-2019 | 11:55 AM
  #2205
If you are talking about the Tamiya TCS series GT Pro Spec class, I doubt the SR will be legal if it's based on an upgraded S chassis, as the rules for that particular class specifically exclude the TT-02S. At least in 2019...
https://www.tamiyausa.com/media/file...s-962-a4df.pdf
If you are referring to a different series, ignore me and carry on.
Helios is offline
