Tekno RC ET410 Thread
#962
Can you show a pic of how it's not fitting? The only reason I can see it not working is that when the arms are flipped the mounts for the swaybar (on the arm) are too far away and puts the plastic part connecting the arm to the bar at too much of an angle, which would cause it to bind on the ball at droop.
ET410 forward shock mount fitting woes
I might be able to install the sway bar into the mount, then install the mount, but to do that you'd have to de-install bunch of other stuff first, and it would make working on the truck harder.
#967
The rear bulkhead and the brace/body mount is exactly the same in both EB and ET...there is no reason it would fit in one and not the other.
Put the bar in place first then the plastic part on top instead of trying to put them both in together.
#969
i just got them in the mail today from Amain. It says not to put them on the front and I’m not sure why. I put them on all 4 corners to see what it would feel like and it was good. I honestly couldn’t tell much of a difference between my Tekno +2mm or whatever their largest offset is.
#970
#971
Raced my ET410 for the first time on sunday. This thing is a ton of fun.
Ended up not finishing, a few laps from the end, because a steering link popped off.
I have a beefy servo, so I'm wondering if there's a need to replace/upgrade the steering links to the hubs. Anybody done this?
Or am I overthinking it?
#972
#973
Wanted to say I have been having a blast racing my ET410 lately.
Baby truggy is hooking up using the stock set-up (a bit heavier oil in the rear shocks) running worn-out positrons (S3) on a hard packed dirt track.
#974
#975
Is there a goto esc/motor combo? Been reading all day and the more confused than when I started. Lol
Also what servo would work with a 4pv?
What do you guys think of reedy 510r an reedy 6.5?
469Likes
