Tamiya TT02 Thread
#2071
I am a die hard TC racer but have had a few Hahn trucks in the past. Being super impressed how quick / good a box stock TT01 does with a truck body got me intrigued to build my first TT02 GT style kit. This is a box stock build with bearings / USGT tires. Once I mentioned it to my local race buddies they decided to grab some TT02 kit's as well and create a new class for our track. Rules being bearings, stock pinion size and hex screws permitted. Must use Tamiya Bodies only. This should help bridge the gap between a fresh new comer and a $1200 TC set up. The cars can always be upgraded with some key parts and put into another class like VTA or Usgt even.
I opted for the new S550 GT4 stang kit and got it done
Packed the diffs with Aw grease and the first few packs the car was on the money right off the bat. For reference the fastest VTA cars were 9.7 fast laps to 10.5 mid pack. I could click off 10.0-10.2's almost every lap with this TT02 and it looks great doing it. It's not insane fast but the Silver can always does good by me! Nice water break in with some oil on the bushings and away it rips. I still have to finish the head light buckets but I will have a Raikiri body to try shortly. Not great pics as of yet but here's a couple to get the idea
#2072
#2073
As seen in the pic ready to race coming in at 1380g currently with a 275-280g battery weight. Shortening the ESC wires alone was worth 10-12 grams off the top of my head but I really did it just to be tidy and neat. I also removed the orange wire right off the ESC board as I will stick with the silver can. Can always solder it back in though if I choose
#2076
Thank you,
So you pretty much have to do the lowest FDR allowed 64/29, and you’re still way off. Normally you would run around a 3.8 for your average size race track but thats not GT Prospec legal. 64/44 in a perfect world.
Can you use an Xray T4 gear maybe or probably not legal huh.
#2077
Thank you,
#2078
What you need to do is ditch the Tamiya .6 module gear set all together. So buy the Tamiya "high speed gear set for the TT02" Which all you really need is the alum adaptor for the spur (don't use the supplied .6 module spur) Then buy a yeah racing adjustable alum motor mount and convert it to 64 pitch. You will need some wild gears to get it close to 3.8-4.2 FDR.. like a 80-82 spur spur and 50-53 pinion.
#2079
Absolutely! I almost want to take my box stock TT02 posted above and swap it out for a proper 64pitch FDR set and see what a stock kit geared can really do lol..
#2080
You can go low with the TT02
std motor mount, but fitting 64dp gears
https://www.thercracer.com/2013/07/how-to-gear-tt02-for-175t-blinky-with.html
adjustable yeah racing mount
https://www.thercracer.com/2014/04/tamiya-tt02-175-215-and-vta-blinky.html
#2081
Thank you for the info, that will help me down the road if I run a non TCS GT Pro Spec race but for this build its not legal to make those changes. It looks like we are stuck with the 64/29 combo. This was just a cheap and easy second class at one of my local tracks.
- Spur Gears permitted: Tamiya TT-02 stock and TT-02 Tamiya speed-tuned spur gears are allowed. TT-02: Stock 70T, Speed-Tuned 68T and 64T
- Pinion Gears permitted: Pinion gear ratio options shown in the TT-02 kit and the speed-tuned gear set motor mount chart instruction manuals may be used. Finding ways to exceed the maximum gear ratio shown in the manual charts is not allowed. Maximum gear ratio from the speed tuned gear set: 5.74:1 (64T Spur-29T Pinion)
#2083
Update on my Box Stock TT02 Kit. I got the Tamiya Raikiri Reg weight body all cut, painted and mounted. In my TC Style One color wonder / sponsor stickers :P
This lid came in at 128 grams ready to go. Versus my GT4 Mustang body of 148 grams, mind you I put more stickers on the mustang but the shape and low CG the Raikiri helps for sure. On track performance on a new layout I had the Mustang body clicking 10.4-10.5 almost every lap and a 10.3 as fast laps. Putting the new lid on I slammed the posts down and sent it out. Right away I could feel a Touring Car type effect and the car was smooth everywhere. I could push it as hard as I wanted and the car was planted with better steering and much less body roll. (Especially on the stock friction shocks). I ended up hitting 10.2 - 10.3 like 20-30 times and fast laps were 10.1's. Over all super happy with this body as far as performance but mainly I love the look of it as well. The body lines on the Raikiri remind me of the older NSX Bodies
I may buy a lightweight version in the future just for some quick laps when I feel I want it :P Overall this Stock TT02 has been a blast for me, it's a filler in between my hardcore 17.5 Race car and requires very little to nothing to keep it going.
#2084
the high speed gear set comes in 48p. It was included with the TT02-RR. I run 48pitch on my X-ray and have some pinions and although these ‘could’ work, they are not the same. The length of the teeth on the regular pinion is shorter or and maybe thicker so it makes a contact sound... which means friction unless I back it off but then risk stripping the spur. Oh well no biggie I thought there was a pinion option besides Tamiya. I may just end up changing the spur to traditional 48p and be done with it. Thanks anyway for the feedback.
#2085
The stock speed controller TBLE-02S in my TT-02 seems to be working, but it would sometimes seems to be having issue. When I punch the throttle hard, the car would accelerate for a second then stop as if the battery is completely drained. Then after another second or two it would resume power. I've made sure the battery is fully charged, and this still happens sometimes. When I don't punch the throttle like this, it usually doesn't have a problem. This happens with the stock brushed motor. I've ran another brushed motor and still same issue, so I don't think it's my motor. I did set up the ESC per the instruction ... Anyone else ever experienced this? It's a really annoying glitch whenever it happens.
1387Likes
