Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-14-2019 | 02:45 PM
  #2041
Originally Posted by r_torres
any brands that produce hex screws for the tt02? i really dislike the philips. suggestions welcome!
I end up buying bulk m3 machine screws off of ebay every so often. It's not a lot of money to get all the screws you might need.
Nerobro is offline
Old 05-14-2019 | 03:51 PM
  #2042
Josh L's Avatar
Here's a decent deal on M3's and it's prime to.
600 Pcs Metric M3 DIN912 Stainless Steel 304 Hex Socket 600 Pcs Metric M3 DIN912 Stainless Steel 304 Hex Socket
Josh L is offline
Old 05-14-2019 | 04:56 PM
  #2043
Originally Posted by DaSilva3525
Yeah Racing sells a Ti screw kit for like $14. I have used them in the past and they are decent for the money for sure
sweet $15 plus shipping doesn’t bad. not like tt02 type s titanium screws that’s like about $44-$55 bucks depending where you get them.
r_torres is offline
Old 05-14-2019 | 05:08 PM
  #2044
I really recomend against buying stainless screws.
Nerobro is offline
Old 05-14-2019 | 05:12 PM
  #2045
If you're gonna do it, do it right:
Amazon Amazon
you'll need some countersunk too...
Amazon Amazon
Really though, I go with ebay, and buy the exact kinds I need.
Stainless always goes "soft" and tears under load.
Nerobro is offline
Old 05-14-2019 | 07:47 PM
  #2046
Raman's Avatar
Magnetic bits also do not grab stainless steel screws.. which makes it more of a hassle in tight areas
Raman is offline
Old 05-21-2019 | 12:20 AM
  #2047
so i pulled the trigger and got myself a tt02rr from towerhobbies. regular shipping only took two days! great service!
looking into universal shafts. i was looking at the 54515 from xv-01. would it with the tt02rr? also should i replace front and rear? tia
rippen likes this.
r_torres is offline
Old 05-21-2019 | 07:13 AM
  #2048
You have to to go with Tamiya 53792 if you want to use original Tamiya parts. 54515 will not fit TT-02 RR machine, they are too long.
Regards
Michael
JJ100179 is offline
Old 05-21-2019 | 11:42 AM
  #2049
Regards
Michael
would you also have to buy the cup joint to fit the universal shafts?
r_torres is offline
Old 05-22-2019 | 04:28 AM
  #2050
Default Not necessary...
...Kit stuff works fine with the universals.
But you can upgrade the grub screw secured wheel axles with spring fixed ones. (Tamiya Part number 54623)
Michael
JJ100179 is offline
Old 05-23-2019 | 03:52 PM
  #2051
proliteandsc's Avatar
Default Need rear downforce
Looking to get a new body with lots of downforce in the rear. I can only use a Tamiya TT-02 body, and can't add rear wings. Anyone know which one would have the most, or what I should be looking for?
proliteandsc is offline
Old 05-23-2019 | 04:37 PM
  #2052
DaSilva3525's Avatar
Check out the Raikiri Body from Tamiya. Comes in box stock form so you should be good to use it.
DaSilva3525 is offline
Old 05-24-2019 | 05:58 AM
  #2053
I'll probably get that one.
Old 05-24-2019 | 12:39 PM
  #2054
Scionara05's Avatar
The kit tires tamiya 51049 medium compound are good for what surface carpet or asphalt. Rather use them up on practice days than have them sitting in a box
Scionara05 is offline
Old 05-26-2019 | 10:42 PM
  #2055
They're ok for ashphalt.
No good for low-grip carpet.
Bloke is offline
