Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-13-2019 | 11:30 PM
  #2041
Originally Posted by Nerobro
Nope, i'm talking about the ring and pinion gear that is on the outside of the diff. I believe I"ve broken 4 pinions now.
You have 2 options. GPM make the gears in metal, so you can buy the full set including the internals which is expensive, or just the ring gear which is also expensive for a single gear but less so. RCJaz have the GPM gears
Or grab metal parts bag from the DF02 and the gear cases. This gives you enough to build 2 diffs for the price of a single GPM set. You need to file the pinion down a bit. I'm pretty sure its bag a, part 9400152, but you better check.
As a bonus the bag includes other bits like a 19T steel pinion which is a good match for a 13.5T and a bunch of those annoying self tappers Tamiya insist on using (I love Tamiya but wish they'd use proper hex head screws and bearings instead of bushings). Oh and another Tamiya hex wrench, you can never have enough of those.
I find that the metal gears slow the car considerably on the stock motor (have a couple TT02B's for my 5yo and his friends) but the 13.5T brushless setup like you suggested is the perfect match for the chassis and you don't notice the car being slower with metal gears on this setup.
Nerobro likes this.
jgil089 is offline
Old 05-13-2019 | 11:44 PM
  #2042
The GPM gears (which I own..) are just the ring gears. Sadly.
So.. those gear sets, are the three gear sets, like in a TT01, so I'll need the TT01 casings to match that. STill, not a bad deal.
.................................. This is such a bad idea. But I really want this TT02b to work. hah.
Nerobro is offline
Old 05-13-2019 | 11:49 PM
  #2043
Yep the DF02 gear set is the 3 gear so you need the cases
If you have the ring gear already...
https://www.rcjaz.co.nz/tamiya-tt02b-steel-propeller-shaft-gear-1pc-for-tt02-gpm-tt2100g2-p-90071612.html
thats the one you need right? There is also the complete set
https://www.rcjaz.co.nz/tamiya-tt02-steel-ring-gear-bevel-8pcs-set-for-tt02b-gpm-tt2100-p-90070804.html
you should see some of the builds on tamiyaclub, go nuts on the TT02, end up spending more than a TA07 /DB01 and they still won't perform as well. Fun though
Nerobro likes this.
jgil089 is offline
Old 05-14-2019 | 02:16 PM
  #2044
any brands that produce hex screws for the tt02? i really dislike the philips. suggestions welcome!
r_torres is offline
Old 05-14-2019 | 02:32 PM
  #2045
DaSilva3525's Avatar
Yeah Racing sells a Ti screw kit for like $14. I have used them in the past and they are decent for the money for sure
DaSilva3525 is offline
Old 05-14-2019 | 02:45 PM
  #2046
I end up buying bulk m3 machine screws off of ebay every so often. It's not a lot of money to get all the screws you might need.
Nerobro is offline
Old 05-14-2019 | 03:51 PM
  #2047
Josh L's Avatar
Here's a decent deal on M3's and it's prime to.
600 Pcs Metric M3 DIN912 Stainless Steel 304 Hex Socket 600 Pcs Metric M3 DIN912 Stainless Steel 304 Hex Socket
Josh L is offline
Old 05-14-2019 | 04:56 PM
  #2048
sweet $15 plus shipping doesn’t bad. not like tt02 type s titanium screws that’s like about $44-$55 bucks depending where you get them.
r_torres is offline
Old 05-14-2019 | 05:08 PM
  #2049
I really recomend against buying stainless screws.
Nerobro is offline
Old 05-14-2019 | 05:12 PM
  #2050
If you're gonna do it, do it right:
Amazon Amazon
you'll need some countersunk too...
Amazon Amazon
Really though, I go with ebay, and buy the exact kinds I need.
Stainless always goes "soft" and tears under load.
Nerobro is offline
Old 05-14-2019 | 07:47 PM
  #2051
Raman's Avatar
Magnetic bits also do not grab stainless steel screws.. which makes it more of a hassle in tight areas
Raman is offline
Old 05-21-2019 | 12:20 AM
  #2052
so i pulled the trigger and got myself a tt02rr from towerhobbies. regular shipping only took two days! great service!
looking into universal shafts. i was looking at the 54515 from xv-01. would it with the tt02rr? also should i replace front and rear? tia
rippen likes this.
r_torres is offline
Old 05-21-2019 | 07:13 AM
  #2053
You have to to go with Tamiya 53792 if you want to use original Tamiya parts. 54515 will not fit TT-02 RR machine, they are too long.
Regards
Michael
JJ100179 is offline
Old 05-21-2019 | 11:42 AM
  #2054
Regards
Michael
would you also have to buy the cup joint to fit the universal shafts?
r_torres is offline
Old 05-22-2019 | 04:28 AM
  #2055
Default Not necessary...
...Kit stuff works fine with the universals.
But you can upgrade the grub screw secured wheel axles with spring fixed ones. (Tamiya Part number 54623)
Michael
JJ100179 is offline
