OS TR engine thread
#556
along with my tzr engine i also purchased a tr r spec used from a mate that had just run 3 break in tanks at idle
ill be using this engine for my club days and the tzr for race events
cant wait to tune this engine
is the os p6 plug best for this engine ?
ill be using 15%nitro fuel
#558
Yeh last weekend, got 10 tanks through it, its got some pep! It was a bit of a bitch to get started the first time to break it in, but once I got the initial break in out of the way and finished with the rest of the fun the engine runs fine. My old STS/HPI .12XS was a bit easier to break in, but the OS is a bit more stable it seems.
I also bought a STS D3R 3 port modified motor to use in some series races I am going to try and run (3 port only rules for the series)
#559
hello
wats a good turbo low plug to use with the os tr r spec ??
i am using 15% nitro fuel, the engine came with a p6 glow plug so would be best to continue with this plug ?
thank you
john
thank you
john
#560
just to give credit to this os tr...last weekend was the 2nd race for this tr...and the results were still something like a dream to me....i got 3rd A main...it was real hard for me to qualify, only in the last heat i was able to put myself into the A main group..qualified 9th...
although it was my 3rd time qualifying in A, i didn't had any high hopes , maybe just to finish the race one or 2 placing better than i started, especially with the other regular A main faces and mostly italian power plant...
besides the reliablity and competitive power by the tr...the pit and driving strategy also help achieve the good results....my plans were simple , a 6 min. 30 second per refuling time, start last following the rest of the pack...after the 1st refuel i heard the announcement that i was 2nd trailing 1 laps behind the leader...as the race went on i was switching places 2 and 3rd...at one time i drop to 4th..halfway through i was thinking 'this time i can do it at least nd or 3rd...i just have to keep focus and do not overconfident...and the race ended and i felt so good.... anyway now i have more confidence in future races....tq
#562
Originally posted by Tire Chunker
Does any one run the McCoy MC-59 with the 12TR?
Is it to hot of a plug?
mc59 is a hot plug
the OS A3 ran great on my OS TR with 30% fuel
#563
hello
trying to get my r spec to have a good tune its hard for some reason....
i have the top end running awesome and the car temps are around the 110degrees celsius mark, however the problem im having seams to be in the low end..
i can start the car and warm it up on the bench then it normally stalls within about 10 seconds and i need to restart it thewn it runs sweet
one of the guys at the track said it seams to be loading up on fuel ??
can i get some help please ?
thanks
thanks
#565
Hi guys,
I don't really have a problem but a slight worry about my engine temps. I have an OS 12 TR(P)T 5port.
I run it as rich as possible, any richer and it dies the moment I throttle it. But the temp is still around ~135celcius.(taken at glow plug area) Ambient temp is around 33celcius. It runs fine and has decent power. I can lean it somemore coz I tried it before and there's still some power to be tapped.
But I'm worried about the engine temp. Anyone out there with this engine can give me some readings on their engine temp?
I'm also contemplating putting on a larger head. Any company out there makes a large head that fits the OS?
Cheers...
Cheers...
#566
Try this http://www.rcaddict.com.au/product_i...roducts_id/126
My os engine did the same thing i eventually sold it
#570
hello
i just wanted to know what percentage oils you guys are running in your tr (mine is a r spec tr) ??
i am currently using 15% nitro with 18% castor oil
i notice alot of brown carbon like build up inside my egine on top of the ppiston and out side the car
thanks
john
thanks
john
