Tekno RC EB48.4 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree311Likes
Last edit by:
Print Wikipost
Old 03-21-2019 | 09:21 PM
  #1636
PorTX's Avatar
That’s what I thought was weird. Every thing I heard was go to a longer link when track is loose. So my plan was to try the shortest link possible....then make the longest link possible to compare. I set the buggy down and could tell within a lap it was so much better with the short link. On Sunday (full prep track with water), even with higher grip it wanted to break the back end loose coming out of the corners. Then with the changes...On the dry loose track I was able to take the throttle expo out and it would accelerate straight and hard! Can’t wait to see what it does on the track when it is watered and high(Er) grip!!
PorTX is offline
Old 03-22-2019 | 01:17 PM
  #1637
suzukipro's Avatar
Originally Posted by Skaar_rc
We got a very loose outdoor track in my place too. Currently running 7-5-3 for diff and longer camber link for both front and rear. Also I drop to the lowest hole for camber link on the tower to give more roll. I really like the current setup but thinking to add overdrive ring and pinion for the front diff.
the top holes on the tower are low roll the lower holes are for high roll.
suzukipro is offline
Old 03-22-2019 | 01:49 PM
  #1638
suzukipro's Avatar
I tried the longer links and also noticed improved traction once I started running with with short links too.
Old 03-22-2019 | 08:25 PM
  #1639
Did i said anything wrong?
Skaar_rc is offline
Old 03-25-2019 | 01:45 PM
  #1640
suzukipro's Avatar
The lowest holes on the tower (high roll center) gives the least amount of chassis roll, a low roll center will increase the amount of chassis roll.
Old 03-28-2019 | 08:33 AM
  #1641
kcooper273's Avatar
Ryan Lutz's website is down since he switched to Agama. Is there anywhere else around that would have his PNB setup sheet? Getting my car prepped for next weekend.
Thanks!
kcooper273 is offline
Old 03-29-2019 | 07:34 AM
  #1642
i've got it
kcooper273 likes this.
kryss is offline
Old 03-29-2019 | 10:01 AM
  #1643
hairymuffin's Avatar
Always remember a new car will be loose because it needs to wear in
hairymuffin is offline
Old 03-30-2019 | 01:39 PM
  #1644
Matthew_Armeni's Avatar
+1
Any new car needs about an hour of actual track time before it really feels "correct". This is especially true of 8th scale vehicles.
Matthew_Armeni is offline
Old 03-30-2019 | 01:49 PM
  #1645
PorTX's Avatar
Starting to work on shock tuning. The stock pistons are 4 x 1.9 holes. The rough track setup sheet shows 3 x 2.1 hole (front) and 3 x 2.0 hole rear pistons. That makes a smaller surface area of holes. So in theory that would slow the shock compression down? Is that correct?
Trying to figure out a rough track shock setup. Would a quick reacting shock work better or a slower stiffer shock work better in the rough?
PorTX is offline
Old 04-01-2019 | 08:11 AM
  #1646
kcooper273's Avatar
Originally Posted by Matthew_Armeni
+1
Yes, luckily Friday is a practice day, so I should get ample track time.
kryss: Thank you!!!
Old 04-04-2019 | 04:18 AM
  #1647
Does the m2c game changer wider
Chassie can it be installed on the eb48.4 buggy at all
MadMick is offline
Old 05-05-2019 | 03:27 PM
  #1648
Driving on a loose dirt, going to a straight away to 180. My rear looses traction when breaking, do you guys set your brake force to less than 100% I already tried to lower my shock oils and spring but still could not perfect the turn unless I really go slow on the straight.
stinger84 is offline
Old 05-05-2019 | 07:34 PM
  #1649
I usually set my brake strength to around 70% on the ESC then dial it in with brake dual rate on my radio. It's very track dependent, but I typically I like my brakes to be as strong as possible without locking up. After dialing in your brakes let us know if you still have off power rear traction issues.
Old 05-05-2019 | 07:35 PM
  #1650
Sounds like it's locking up the tires, definitely turn down the brakes. None of my cars brakes are at 100%.
nitrousdave is offline
