Tekin Rx8 Gen3 Thread >
Like Tree85Likes
Old 02-18-2019 | 09:30 PM
  #256
Randy_Pike's Avatar
Team Tekin
Relax guys, lots of tracks limit the batteries on indoor 1/8 cars. It's certainly not new.
The Rx8 is the clear choice for ESC, but motor wise you have a few options:
1. Go with a 3s and T8i 2700kv
2. Go 2s with a Pro4 HD 4300kv
3. Convince the local track that 4s is more efficient and simply follow the 1/8 "Lite" class rules I posted a few years back(you can Google it). Simply run 4s and limit the KV and diameter of the motors being used to reduce power, etc.
Randy_Pike is offline
Old 02-18-2019 | 11:47 PM
  #257
PorTX's Avatar
So for outdoor large tracks, running 4s....is the 1900 still the normal motor found in top level drivers cars? Or have the new 2000, 2050 and 2100kv motors proven to be better choices for 4s outdoor tracks?
PorTX is offline
Old 02-19-2019 | 10:24 AM
  #258
The 1900 is the most popular choice on 4s. If you are on a very large track or need to clear larger than average jumps, the 2050 will get you there. The 2000kv and 2100kv motors are meant for truggies as they are the long can versions.
Motor Length:
4030 Buggy 69mm / 2.71"
4038 Truggy 77mm / 3.03"
PorTX likes this.
Krio is offline
Old 02-19-2019 | 08:26 PM
  #259
Randy_Pike's Avatar
Team Tekin
I prefer the 1900kv. Some like the 2050.
Old 02-20-2019 | 11:44 AM
  #260
ta_man's Avatar
Saying "I prefer" implies you have a reason. Would you share your reason(s)?
I think that is what people would be interested in and we might learn things to consider that some of us hadn't thought of.
ta_man is online now
Old 02-20-2019 | 03:22 PM
  #261
PorTX's Avatar
That is what I was trying to learn. I am thinking the 1900 might have a smoother powerband? If the 2050 just had more top end I could see the top level guys wanting that. However, wheel spin is always an issue with outdoor 1/8 racing so a flater torque curve would make the power more predictable? Who knows? Seems to be a question very few want to tackle?
PorTX is offline
Old 02-21-2019 | 06:01 AM
  #262
UK.hardcore's Avatar
1900 is a why wind, 2050 is a delta wind. imo, delta is sometimes a bit harsh.
UK.hardcore is offline
Old 02-21-2019 | 12:41 PM
  #263
Randy_Pike's Avatar
Team Tekin
The 1900 is a wye wound motor very similar to 1/10 motors we race often. The 2050 is a delta wound motor so it's more of a nitro power band; softer on bottom with a good mid range hit. I prefer the linearity of the 1900 and wye wound motors.
Old 02-22-2019 | 08:39 AM
  #264
azdakota97's Avatar
Randy,
I was curious. I had 2 gen 2 rx8's go dead on me after hard landings at the new Nitro Compound track and it kept me from running their first nitro warm up race. I have since obtained a new rx8 gen 3 and was instructed to use zeal tape under it and also to open the case and add a layer of servo tape under the board. Is that last step really needed? Thanks for any input.
azdakota97 is offline
Old 02-22-2019 | 09:54 AM
  #265
TY@TEAMTEKIN's Avatar
Team Tekin
Originally Posted by azdakota97
Randy,
No, you don't need to open it up, there is plenty of support inside the GEN3.
azdakota97 likes this.
TY@TEAMTEKIN is offline
Old 02-22-2019 | 10:18 AM
  #266
Opening up the case to add extra support was a Gen 1 trick. Definitely isn't needed anymore and might even stress the components more.
Krio is offline
Old 02-22-2019 | 11:50 AM
  #267
azdakota97's Avatar
Awesome. Glad to hear that. I didn't really want to. Thank you for the quick replies!
Old 02-23-2019 | 06:43 AM
  #268
Note: This question relates to the RX8 Gen I, that I have put in a RX8 Gen 2 case, but this RX8 thread is more active. Also, this question might be a generic ESC mounting questions as well.
I have a Losi SCTE, but I'm running it with an 1/8 scale buggy body, Badlands MX28 wheels, Tenshock SC411 4700kv, 11t pinion, Gensace 2s 5000mah 50c.
My RX8 Gen 1 case started to crack about about 18 months after I installed it, then I moved and stopped using my SCTE for a few years. About a month ago I started repairing and upgrading my truck and that included replacing the cracked Gen 1 case with a new Gen 2 case. I had to open up the hole for fan plug a little, but other than than everything went together smoothly. I had previously learned that double sided tape does not hold very well, so I fastened the ESC to the plastic mount with small screws from below into the supplied mounting holes on the case. I ran a few packs through it on flat ground doing some tuning and testing. Then yesterday I took it to a dirt jump track and after three modest jumps (landing on the down slope from about 4'-0" high) the Gen 2 case completely cracked in half and appears to have separated the boards inside. See attached photos.
My questions are as follows.
  • From what you can see in the photos, does it appear that I have installed the ESC incorrectly that would increase the chances of damaging the ESC while landing jumps?
  • I don't race anymore and just plan on bashing and jumping, instead of investing over $200 into a new RX8 would my money be better spent purchasing a Mamba Monster or a Hobbywing XR8 (the aluminum case appeals to me)? Are those ESC's typically more durable than the RX8?
Thanks in advance for any help or input!
Apexscalpel is offline
Old 03-04-2019 | 06:28 AM
  #269
Unfortunately, I think you need to have more posts before you can share pictures. Can you upload them to another site and post the links? Definitely hard to comment without the pictures.
At the very least, don't toss the esc. Tekin offers the ability to send in your old RX8 in any condition for a discount on a brand new Gen3 RX8. I want to say it would be about $140 to exchange your broken setup for a Gen3, which is way more durable than the gen1 or 2.
Randy_Pike likes this.
Krio is offline
Old 03-11-2019 | 09:27 AM
  #270
if i decrease brake strength but increase rpm brake that should lower the high speed braking but keep the low speed close to where it is now , right?
