Like Tree21Likes
New LRP Flow Esc
Old 02-26-2018 | 04:56 PM
  #1786
silden's Avatar
Originally Posted by nova2015
Small issue with my Flow X offroad.
I have installed it into a TC, so bought the new USB bridge and set about installing V5.4 to run in blinky mode.
Installation successful, but unable to do reset, only get a solid blue light and no response from ESC. (reset was attempted a few times )
Reinstalling the original firmware ( V3.1) sees reset and calibration successful, and ESC works fine. Then downloaded a fresh copy of V5.4, also tried V4.7 to test my theory, with same results. Will not work on new firmware, but reinstalling old firmware it works just fine.
It looks like you have downloaded the Firmware of the old Flow.
The correct Firmware should be FlowX 5.2
You can download it frm LRP.CC
gigaplex likes this.
silden is offline
Old 02-26-2018 | 05:04 PM
  #1787
nova2015's Avatar
I'll check the file, but I believed it was the correct file as it had an 'lrp2' prefix.
nova2015 is offline
Old 02-26-2018 | 05:12 PM
  #1788
silden's Avatar
I believe both have the same extension.
silden is offline
Old 02-27-2018 | 03:32 AM
  #1789
nova2015's Avatar
So, reworked it this evening. Confirmed that the firmware I had installed prior was indeed correct but deleted and downloaded new copy anyway.
Installed new firmware, took multiple attempts to get reset to effect. Was then able to calibrate. ESC works fine. Switched off, came back later and switched back on. Solid blue light, no response.
Reloaded original firmware, everything works perfect first time.
Thoroughly confused and frustrated!
nova2015 is offline
Old 03-11-2018 | 12:51 AM
  #1790
Jochim_18's Avatar
after installing the new firmware don't reset it just re-calibrate the ESC.
Jochim_18 is offline
Old 03-11-2018 | 01:08 AM
  #1791
Jochim_18's Avatar
Originally Posted by bornox
i think the hidden value how to access it is on the manual.
Can use access the hidden mode/Value?
Old 03-14-2018 | 11:36 PM
  #1792
hana166's Avatar
Exactly the same problem here except mine was a TC on 4.1, went to 5.2 solid blue light, corrupted, went back to 4.1 esc works fine. Now they've gone bust. Game over unless someone here knows a fix.
hana166 is offline
Old 03-16-2018 | 04:03 AM
  #1793
i hv always wonder why the same unit of FlowX preloaded with different firmware is sold at different price.
I hv found that in general, FlowX preloaded with off road firmware is the cheapest relatively.
Now, if yiu cannot change the preloaded firmware, this explained the price different.
hobbs is offline
Old 08-13-2018 | 01:41 PM
  #1794
No9's Avatar
No9
I have a brand new 3 day old flow x tc spec that has never been run because i'm having issues during calibration. I hold down the set key and the green light comes on but when depressed it goes back to solid blue, eventually it will calibrate but when turned off and back on it has lost calibration and there is a solid blue light again. Have tried 2 motors and 4 sensor cables but nothing helps.
No9 is offline
Old 09-02-2018 | 04:55 AM
  #1795
I am on the X20 13.5t motor.
I read somewhere the timing tabs can be installed in reversed to get higher timing. Anyone knows the exact/updated/new timing value if it is in installed in reversed?
airbiscuit is offline
Old 11-05-2018 | 02:15 PM
  #1796
bornox's Avatar
anyone tried lrp flowx on 1s?
bornox is offline
Old 11-05-2018 | 02:20 PM
  #1797
silden's Avatar
We run it with a Trinity Lipo booster and it works quite well in Mod.
silden is offline
Old 11-05-2018 | 03:40 PM
  #1798
bornox's Avatar
u think the hw 1s booster works? just running 13.5t
bornox is offline
Old 11-05-2018 | 04:34 PM
  #1799
beyondthepack's Avatar
Just updated the new 4.2 software for the TC. Is it just me or is the brakes better?
beyondthepack is offline
Old 11-05-2018 | 04:44 PM
  #1800
silden's Avatar
Yes it should work fine.
silden is offline
