Like Tree21Likes
New LRP Flow Esc
Old 11-05-2018 | 07:11 PM
  #1801
bornox's Avatar
Originally Posted by silden
Yes it should work fine.
thanks! appreciate ur input.
bornox is offline
Old 11-07-2018 | 09:29 AM
  #1802
Have the Nosram Comet HD and seeking a way to get it tuned and updated without buying the damn expensive original USB Card. Any Chance there is a cheap china clone?
man1ac is offline
Old 11-12-2018 | 10:52 PM
  #1803
Hi guys, running the flow works speedo it has software from 2015 on it atm and Thinking of upgrading to the new flow x. Is there a major difference in thes speedos?
thanks
prodriver is offline
Old 11-20-2018 | 01:46 PM
  #1804
A good starting point would be: 3-3-1-6-2-3-5-1-1
The boost/timing will start after 10k with max ramp of 20* and a slope of 10* per 10k.
If the car isn't fast enough you should tune up the slope and then the max ramp.
I would set the end bell timing to 27.5 and the gearing to ~5.5 FDR.
I hope this helps a bit.
hello, for a 10.5t engine with 50º engine timing?
asphalt little grip.
thank you
electrojer is offline
Old 11-28-2018 | 09:38 AM
  #1805
bornox's Avatar
having problem with my flow x with hw 1s booster. everything looks ok but, when i apply full thorttle it has that ticking sound in the motor. does anyone have an issue with flow x with 1s booster like this?
bornox is offline
Old 11-28-2018 | 09:43 AM
  #1806
silden's Avatar
We are using this setup since 2 years without any issues. please make sure that the esc switch is in off position. Or you need the firmware upgrade to mod 4.2/ stock 5.2.
silden is offline
Old 11-28-2018 | 10:38 AM
  #1807
bornox's Avatar
off position? do i need to disconnect the (+) wire from the
esc to the receiver?
bornox is offline
Old 11-28-2018 | 11:44 AM
  #1808
silden's Avatar
We tried to disconnect the + but it was kind of weird, like that the battery voltage was to low under acceleration in mod. This properly isn't an issue in stock.
That's the reason we left the + connected and the switch in off position.
silden is offline
Old 11-28-2018 | 04:20 PM
  #1809
bornox's Avatar
i tried leaving the (+) and switch in off position but both esc and booster gets hot. i guess there is something wrong with my esc or maybe like u said i have to update the firmware.
bornox is offline
Old 11-28-2018 | 04:26 PM
  #1810
silden's Avatar
You can try to disconnect the + and turn the esc on. Maybe it works for you.
In any case you should update the firmware. the x.2 firmware update is mainly made for non LRP motors to improve the sensor readings.
silden is offline
Old 11-28-2018 | 05:56 PM
  #1811
bornox's Avatar
thank you. appreciate ur time.
bornox is offline
Old 12-15-2018 | 02:29 PM
  #1812
snopro31's Avatar
does anyone know of other threads with info on the flow x? seems everyone knows the flow x has issues with flashing locked rotor and I have heard programming and I have heard re bind radio as well as you have to buy a special sensor wire. I can not find any actual people with the problem and then having it fixed and what they did.
yes I am having the issue now with one
snopro31 is offline
Old 12-15-2018 | 03:02 PM
  #1813
silden's Avatar
The problem is that LRP hasn’t got any Distributor in the US.
We’re working with LRP to bring the products over and get the support back on track.
silden is offline
Old 12-15-2018 | 05:19 PM
  #1814
snopro31's Avatar
Yes thank you , but my question isn’t about who is going to distribute the product it’s about what people are actually doing to solve this problem if anything.
snopro31 is offline
Old 12-15-2018 | 05:29 PM
  #1815
silden's Avatar
We didn’t had these issues, but the described issues sound like that the voltage level of the sensor is different to the ESC.
You’ll need the special sensor cable from LRP to solve this issue. Unfortunately no one currently offers this part here in the US.
Thanks,
Denis
silden is offline
