New LRP Flow Esc
#1786
Small issue with my Flow X offroad.
I have installed it into a TC, so bought the new USB bridge and set about installing V5.4 to run in blinky mode.
Installation successful, but unable to do reset, only get a solid blue light and no response from ESC. (reset was attempted a few times )
Reinstalling the original firmware ( V3.1) sees reset and calibration successful, and ESC works fine. Then downloaded a fresh copy of V5.4, also tried V4.7 to test my theory, with same results. Will not work on new firmware, but reinstalling old firmware it works just fine.
The correct Firmware should be FlowX 5.2
You can download it frm LRP.CC
#1787
I'll check the file, but I believed it was the correct file as it had an 'lrp2' prefix.
#1789
So, reworked it this evening. Confirmed that the firmware I had installed prior was indeed correct but deleted and downloaded new copy anyway.
Installed new firmware, took multiple attempts to get reset to effect. Was then able to calibrate. ESC works fine. Switched off, came back later and switched back on. Solid blue light, no response.
Reloaded original firmware, everything works perfect first time.
Thoroughly confused and frustrated!
#1792
#1793
i hv always wonder why the same unit of FlowX preloaded with different firmware is sold at different price.
I hv found that in general, FlowX preloaded with off road firmware is the cheapest relatively.
Now, if yiu cannot change the preloaded firmware, this explained the price different.
#1794
I have a brand new 3 day old flow x tc spec that has never been run because i'm having issues during calibration. I hold down the set key and the green light comes on but when depressed it goes back to solid blue, eventually it will calibrate but when turned off and back on it has lost calibration and there is a solid blue light again. Have tried 2 motors and 4 sensor cables but nothing helps.
#1795
I am on the X20 13.5t motor.
I read somewhere the timing tabs can be installed in reversed to get higher timing. Anyone knows the exact/updated/new timing value if it is in installed in reversed?
#1796
anyone tried lrp flowx on 1s?
#1798
