Tekno RC ET410 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree469Likes
Last edit by:
Print Wikipost
Old 04-28-2025 | 06:10 PM
  #1381
RossKo's Avatar
Originally Posted by Cain
hmm I wouldn't be surprsied, I think I saw a ET410.2 at some point with AE shocks on it for a carpet track I went to at one point.
I think the Tekno runs 3.5mm diameter shock shafts.
RossKo is offline
Old 04-29-2025 | 06:06 AM
  #1382
Cain's Avatar
As an update, for those looking to do that Hobao pin mod on the rear that says they are 3mm, they are actually 3.5mm thick the 2 packs I got in. I ended up drilling out the a-arm and hingepin hole areas on the carrier inserts to use them. It worked but something to get in mind if you were like me wondering why they were not going into the insert.
Next thing noticed and maybe this is a exotek specific item, but the spindle block I htink what its called, the part that goes into the caster block up front seems to cause the ackermann plates to hit the webbing on AE style front wheels even with a +2 mm offset hex. I had to dremel slightly the corner "L" part for clearance on those.
Cain is offline
Old 07-17-2025 | 07:40 PM
  #1383
ta_man's Avatar
Aside from the obvious effect of making the truck 0.1" wider per side, what would be the effects, good or bad, of running the "Traxxas Lite Wheel" #1972, instead of the Associated offset wheels the truck was originally designed for?
This wheel:
https://www.amainhobbies.com/traxxas...tra1972/p10933
(Asking about effects on the car, effect on the wallet is very positive/beneficial.)
ta_man is offline
Old 07-19-2025 | 04:54 PM
  #1384
rustyus's Avatar
This wheel:
I would think a person would not get as much rotation with less frontend grip. Less chance of traction rolling though.
rustyus is offline
Old 09-11-2025 | 02:18 PM
  #1385
SavageSpawn's Avatar
Default Receiver box
I purchased a used Et410. But it does not have a receiver box? Is do do you have a part number?
SavageSpawn is offline
Old 09-11-2025 | 02:46 PM
  #1386
rayzcar's Avatar
No receiver box for any of the 410 series. You’ll probably have to purchase or print a custom piece if you wanted one.
rayzcar is offline
Old 09-11-2025 | 04:29 PM
  #1387
What do you all normally do?
Old 09-11-2025 | 05:53 PM
  #1388
rustyus's Avatar
It;s not sealed, but: TeknoRC EB410/ET410 V2 Electronic Tray – Raceform RC
mike_G and 76jimmy like this.
rustyus is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
