Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-08-2018 | 04:43 AM
  #1756
Originally Posted by Mini35
Qatmix?
I haven't even seen a pic posted with sway bars. I'm just gonna order some stuff see what I come up with. Only thing I can't get my head around is how to mount the bars on the chassis.
76jimmy is offline
Old 05-08-2018 | 05:15 AM
  #1757
studioRS's Avatar
Looking at the TT02 rear (usingTT02S or similar TA05 arms with swaybar tabs), I'd make a carbon or similar plate to mount to the top of the rear bumper mounting points. Make sure to fabricate enough of the plate to go towards the rear differential as close as you can. You could fasten the swaybar underneath (so it's lower) like the old TA03R-S by making a groove in the plate for the swaybar to ride in and using small bolts, 2mm nut and wide washers. Not sure on the front yet.
studioRS is offline
Old 05-08-2018 | 05:19 AM
  #1758
studioRS's Avatar
Here's my old school TA03R-S to illustrate how the swaybars mount.
studioRS is offline
Old 05-08-2018 | 05:59 AM
  #1759
Default TT02 sway bar mount
maybe model something along the lines of the 54651 upper arm mount bracket but extend it so it protrudes from the front or rear so you can slot it for a bar and then put a clamp on to hold a sway bar down.
Mini35 is offline
Old 05-09-2018 | 04:31 AM
  #1760
Thanks all for your input. I will come up with something. After looking at it a little it really needs to mount to the bulkhead somehow. I think I could make something up with socket screws and some keystock. A better option would be to recast a bulkhead with the bar holders, similar to a DB01.
76jimmy is offline
Old 05-09-2018 | 08:00 AM
  #1761
LJH
I looked at mine last night, A front one looks pretty easy to make up but not so much in the rear. I run my car on a dusty tennis court and the car is pretty tail happy as is even after playing with a bunch of stuff so maybe just a front one would help.
Cheers,
Jim
LJH is offline
Old 05-10-2018 | 08:37 AM
  #1762
Raman's Avatar
Last year when I raced my type S, I drilled 2 holes in lower half of bulkhead and secured the sway bars using the sway bar holder tabs that came with a Top Sabre Car.. they’re a little longer than Tamiya. The movement was not perfect / even but it kind of worked.
My next thought was to use the separate sway bar piece that comes with TA05.. but never tried.. because I stopped racing the Type S..
Car was super capable and I was hanging in there with X-ray T4s .. durability of the chassis was a problem for me. The 2 screws that secure the rear suspension holder are not enough.. and if you catch a rail with the rear axle stub..’it will tear the whole rear end off lol.. did that 3 times! Last time was with the hardened chassis which is now discontinued
Raman is offline
Old 05-10-2018 | 08:52 AM
  #1763
Yea trying g to squeeze some more use out of these chassis. Kids and I used them for TCS novice last year. I'd like to use them for VTA also
eR1c likes this.
76jimmy is offline
Old 05-10-2018 | 10:31 PM
  #1764
Dan's Avatar
Dan
FS: Tamiya TT02 TCS UPGRADE Parts Lot
If anyone is interested in TT02 upgrades for TCS...
Dan is offline
Old 05-14-2018 | 10:06 AM
  #1765
LJH
My Ride USGT tires finally died last week. I was running them with the Carrera body which needs a 3MM offset in the front (easy) and a 9MM offset in the rear (not so easy). A set of 9MM HPI black Emotions came up on eBay so I scooped them up as well as getting the last set of Ride 26MM Radials I could find. I burned a couple packs yesterday morning and the Ride Radials hook up much better on the tennis courts then the USGT tires and their higher profile makes them look a bit more scale.
I am running an under geared 10.5T motor and I have to say it is a blast, it is pretty quick but still gives decent run time. I set my timer for 10 minutes and that is proving to be very safe. When I originally switched from the 17.5 I was nervous that I would start to blow stuff up.Knock on wood I believe this was run 16 & 17 with the 10.5, after 50-55 runs on the 17.5, and no issues at all. This may come down to the fact that the tennis courts get pretty dusty so they do not offer a lot of traction....with the 10.5 I an get some pretty decent four wheel burnouts when taking off from a start.
Cheers,
Jim
LJH is offline
Old 05-30-2018 | 10:51 AM
  #1766
fyrstormer's Avatar
I stumbled across this on eBay today. It's the TT-01, not the TT-02, but still, it seems like it misses the point of the TT model line.
https://www.ebay.com/itm/261607459461
fyrstormer is offline
Old 05-30-2018 | 11:51 AM
  #1767
They're aimed at the people who want bling, more than they want performance. They're "mostly" for the drift people.
Nerobro is offline
Old 06-02-2018 | 08:23 AM
  #1768
Hey guys! New to the forums.
Im building a tt-02 rally setup, i was looking at the Gmade 62mm Shocks, i know the stock shocks are 55mm, but i measured and it looks like the 62mm`s will fit, can anyone confirm?
VikingsLife is offline
Old 06-02-2018 | 01:08 PM
  #1769
Default Sandshaker...
The TT02-T Sandshaker uses 60mm shocks as well. You have to remove some little knobs from the knuckles to give the suspension more travel. Please see sandshaker manual for Details.
I'm doing a mix of Rally TT02 and Sandshaker at the moment and also want to use some 60mm shocks for this thing. Maybe I will use either the Yeah Racing ones or some of the multiple Tamiya choices. Hobbyking offers 61mm shocks from Turnigy, they don't look too bad and are on the cheaper side, but not sure about the quality. Maybe I will give them a try...
​​​​​​Michael
JJ100179 is offline
Old 09-08-2018 | 10:03 AM
  #1770
Raman's Avatar
Thanks to RCRacer update... I learned that the TT02 RR that is being released has an oil filled gear diff!!! That will be a useful part to buy.
also comes with the Hard Blue chassis.. which Tamiyausa had said was discontinued! hmm
NutDriver likes this.
Raman is offline
