Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 05-01-2018 | 03:55 PM
  #7171
Teamhotrods's Avatar
Originally Posted by JoeyE
The reason I asked is because the BMW in the last post looks like it's not cut 10mm. Just wondering. (I know it's a different wing but it looks like the other TAMIYA lexan type)
This local race series is allowing the tamiya wings and the tamiya carbon fiber wings. Looks like Soap is running a little fat... (cheater!?!). Joke!
Im bringing a measuring stick next race... if I show up
Teamhotrods is offline
Old 05-01-2018 | 05:20 PM
  #7172
b20btec's Avatar
Since this is for a local series this particular tamiya wing is allowable. It’s actually less the 10mm cord just the end plates are big. I’ve seen others use it for usgt but when I run usgt I run a cut down tc wing.
b20btec is offline
Old 05-01-2018 | 06:53 PM
  #7173
At our local track series you must run the wing that came with the body or the option Tamiya 53470 LW Wing Set Crbn Pattern. That's the only option wing we run at our track.
Sop runs the option wing on his Beemer.
Joe Maxey is offline
Old 05-01-2018 | 09:40 PM
  #7174
Josh-n-ya's Avatar
P-Zero Joey!
Josh-n-ya is offline
Old 05-04-2018 | 03:49 PM
  #7175
fat500's Avatar
just got a motor analyser and messing with it. What amp draw is optimum for 21.5 usgt . I tuned it to 6 amps. Thoughts?
fat500 is offline
Old 05-04-2018 | 04:02 PM
  #7176
massenb203's Avatar
What is your timing reading for the sensor board?
massenb203 is offline
Old 05-04-2018 | 04:33 PM
  #7177
fat500's Avatar
57 deg. 2973 kv 23488 rpm 5.8 amps fantom f1r works
53 deg 2779kv 22019 rpm 5.6 amps trinity m2 new monster
I tried lower timing and higher timing and these settings seemed to be fastest if i know what i am doing
you mean the 3? I did not mark them down
The fhantom #s were closer like only 1-2 off
the trinity were 4-5 off on one like 2-3 on the other 2
Why?
fat500 is offline
Old 05-04-2018 | 05:27 PM
  #7178
bertottius's Avatar
If this is a newer motor, you should only be around 2-3 amps. 6 is too high. Also, Which analyzer do you have?
bertottius is offline
Old 05-04-2018 | 08:12 PM
  #7179
fat500's Avatar
the new sky rc can read up to 70 deg of timing.
wow 2-3 amps ok will try it
fat500 is offline
Old 05-05-2018 | 02:43 AM
  #7180
bertottius's Avatar
I use a Motolyser to set mine up. Ideally, you want to raise the timing until the amp draw shoots up but there's no rise in KV or RPM. Then dial is back slightly. That usually puts you around mid 2 to 3 amps. Anything higher just generates heat.
iTz Nicholas72 likes this.
Old 05-05-2018 | 10:53 AM
  #7181
fat500's Avatar
monster max results
#1 55 deg 2743kv 21946rpm 5.9amps
#2 50deg 2550kv 20404rpm 3.9a 48-52-51
#3 53deg 2717kv 21743rpm 5.4 amps 51-56-52
#4 56deg 2924kv 23106rpm 7.7amps 54-59-55
which to run? 4 is fastest but poss too much heat? Diff btwn 2-3 ?
what do you guys think? when i ran the test at 3 amps rpm was way down at 18247 at 42 deg timing
fat500 is offline
Old 05-05-2018 | 04:00 PM
  #7182
theproffesor's Avatar
I think you’re over way thinking it. Tell what might give you better results. Get on the motor thread for the motor you want to run, ask what timing to run. Most are set it and forget it. Run the gearing that the fastest guy that runs that motor at your local track runs.
Then drive the car. I mean drive, drive, drive. None of the work you’re doing will matter if you get marshaled a half dozen times during every race.
Now, if you are already at the little to no marshaling, then I still recommend the same process as listed above. If followed, you will be the guy people go to to copy set-up and gearing
godzukihop and mleemor60 like this.
theproffesor is offline
Old 05-06-2018 | 08:13 PM
  #7183
Billy Kelly's Avatar
Tech Prophet
I’ve spent all winter practice in less the ideal conditions. Had one goal, improve on my consistency. Looking like a good start. Have few changes to make before racing starts. But it’s looking like a good starting point. Now next goal is getting on to lead lap. Don’t care if I’m still last. Just get to the lead lap.
gigaplex and JC3 like this.
Billy Kelly is offline
Old 05-12-2018 | 02:22 PM
  #7184
nubs's Avatar
I decided to paint my NSX today.
USGT Here I come!
fat500 and Josh-n-ya like this.
nubs is offline
Old 05-15-2018 | 04:42 PM
  #7185
fat500's Avatar
Nice NUBS
fat500 is offline
