Coax antenna length? >
Like Tree1Likes
  • 1 Post By Roelof
Old 05-02-2018 | 02:28 PM
sosidge's Avatar
Default Coax antenna length?
I bought a generic 2.4ghz antenna to replace the damaged one on my Futaba receiver.
I've noticed it is only about 2/3rds of the length of the original Futaba antenna? Do any of the radio experts know if this will cause a problem? Seems OK in my house.
I also replaced the transmitter antenna at the same time as that was actually completely broken where the antenna folds for storage (not a great bit of design, I don't know why Futaba insist on fitting these external transmitter antennas). I've re-routed the replacement inside the case, away from the other components - again, any thoughts if this will cause a problem?
sosidge is offline
Old 05-02-2018 | 02:55 PM
It is all about the blank end piece, that is the actual antenna an needs to be arround 3.25cm long (1/4 wavelength), the rest is just a coax cable to the antenna like the coax cable at home from the tv to the aireal antenna or satelite dish outside.
sosidge likes this.
Roelof is online now
Old 05-03-2018 | 12:05 PM
Krio is offline
